Question about GE 30 in. JGP337 Gas Cooktop
I have a GE Gas Cooktop . The left side ignitors spark and light the burners. The right side burners do not spark, but the gas flows and those burner can be lit with a match. I have swapped out the sparking units - they all work on the right side. They all don't work on the left side. I replaced the spark module - still doesn't work. The only thing left is wiring and the harnesses don't appear to have anything wrong with them. Plus, isn't it kind of unlikely that the wire is the problem? One other bit of information - the new spark module does not have a spot for the ground wire. Now I am confused - The colors of the wires on the replacement piece do not match my wiring.
  • Anonymous Feb 18, 2010
    It is a correct part - GE replaced the orginal part and included a note with the new part.
David Tolond
    President:
  • 2,501 Answers
As your first check revealed that the right ignitor had failed and the wiring was OK because the problem went with the ignitor, I suggest that you do not need to look any further than the replacement ingnitor.
(You initial tests proved everything was working except the ignitor) . As unlikely as it sounds, check out the new ignitor. Is it the correct one? (you mentioned differences in wiring).
It is dead?
Trust in yourself! your initial diagnosis was correct.
Posted on Feb 18, 2010
frank thomas wilson
  • 10,319 Answers
Take the part back and get the correct one. yours may have been packaged wrong
Posted on Feb 17, 2010
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
OR
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
IGNITER TICKS BUT BURNER WILL NOT LIGHT. GAS IS FLOWING
usually a ground problem. Try cleaning the surfaces of the burner and make sure the hole to let the gas flow to tyhe ignitor is not plugged.
Mar 20, 2010 | GE 36 in. JGP628 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
66 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
