Hi Lindsay. Was the fuji xerox printer plugged into the old modem by a blue ethernet cable ?
When you changed your modem it would have had a device inside it called a dhcp server that allocated the IP addresses to your computers automatically.
Now I suspect that the new modem has a device inside it called a DHCP server that is allocating a different range of IP addresses to your computers from waht it used to be.
Here comes the technical part
On the printer menu screen there should be a network setting option . Take a note of the IP address of the printer it will be 192.168.0.x or 10.0.0.x x being the unknown number. also take a note of the subnet mask . it will most likely be 255.255.255.0
next but I have no idea how to look that up on a MAC IOS system.
you may see the ip address in the printer settings properties in the MAC
you may be able to get your ISP to remotely set up your DHCP server in your router to work in the appropriate ip range to match your printer IP address and to avoid allocating the printers ip address to your computers. Then restart the computers to get new ip addresses.
If you tell them the printers IP address and Subnet mask they should be able to alter the modem's settings DHCP settings for you.
The other option is to get the DCHP IP address range of the modem and subnet mask and change the printers IP address setting and subnet mask to match the DHCP leases range by giving it a much higher number than the computers are most likely to be running on.
so if the range was 10.0.0.1 to 10.0.0.254 with subnet mask of 255.255.255.0 then the printer would be set to 10.0.0.254 and subnet mask 255.255.255.0 The first three left numbers must match they are known as the network component of the ip address 10.0.0.0 or it may be 192.168.0.0 the zero end number is the network address so you can't allocate it to a device. 192.168.0.1 or 10.0.0.1 is usually the modem address.
ISP may be able to guide you how to change the setting on the printer .
I had a client that had a lot of trouble getting a tech to come out and set up their printer to an APPLE system. I was the final Tech that eventually came out and set up the printer .
In networking the subnet mask is used with IP address to get the Network ID. The Network ID is used to identify that the particular IP address belongs to which network. To get the network ID the SubnetMask is AND ed with the IP address in binary format.
Example:-
IPv4 address contains 4 fields and each field is 8bit
IP Address - 192.168.10.2
Subnet Mask (Default)- 255.255.255.0
Binary
192 -> 11000000
168 -> 10101000
10 -> 00001010
2 -> 00000010
255 -> 11111111
Logical AND (formula)
* 0 AND 0 = 0 * 0 AND 1 = 0 * 1 AND 0 = 0 * 1 AND 1 = 1
Dynamic and Static addressing are the two main methods used for IP address assignments. Dynamic IP addresses are automatically obtained and nothing needs to be done on the user end. However, Static IP address information must be configured manually. If you do not have a router, you need to input your static IP information directly into your Apple Macintosh.
Click "Apple > System Preferences." Click the "Network" icon. Click the "TCP/IP" tab. Choose "Manually" in the Configure drop-down menu. Click in "Show" and choose your Ethernet device. This is usually called Built-in Ethernet. Enter your IP address into the IP Address field. Enter the Subnet Mask into the Subnet Mask field. If your service provider did not provide you with one, use the default of "255.255.255.0". Enter the Gateway address into the Router field. Enter the DNS Server into the DNS Servers field. Two should have been provided to you. Push the "Apply Now" button to confirm changes.
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0 If this isn't the correct IP address, you'll need to reset the d-link print serverHope this helps Regards,c0d3
Subnet mask for 86 PCs is more than 64 and less than 128. it means that subnet mask is 255.255.255.128
You can have PC IP address in range 172.31.0.129 - 172.31.0.254
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
your connection won`t drop after this.
I guess you mean the c350 is not printing while Windows said the job has been sent?
If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g.
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
