Question about SanDisk Sansa Clip MP3 Player
Full charge but won't play
It turns on OK, shows a full battery, shows the song that should be playing but the numbers that count when the song is playing don't move
Posted by nleaman on
  • Anonymous May 11, 2010
    It's possible that the song is in a format that the Clip can't handle. Can you play any other songs?
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Its no good sorry
Posted on Feb 17, 2010
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
Hi, my swimp3 was not used for the last 2 months. I charged it up full yesterday and when plugged into the computer it plays well (i.e I can format it, change songs, actually have it "play",...
Hello nehajo88,
Thank you for contacting us. I work in the FINIS Technical Support department and would strongly recommend that you go to our support page and create a ticket so we can process you for a replacement as it seems to be a defective unit. So please visit our support page (http://www.finisinc.com/support/) and create a ticket and I will be happy to further process your case there.
Thanks!
Aug 02, 2011 | Finis Swi MP3 Player
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
Shows full charge but dies within one song
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you have over charged and drained completely , the battery must have been busted.please replace the batteries and if still isnt turning off, check the keypad for any faults.hope your problem is tackled..have a nice day
May 22, 2009 | Microsoft Zune JS8-00001 Digital Media...
Charging trouble
Might be a bad battery.
Feb 09, 2009 | Insignia NS-DV2G MP3 Player
Sansa e250 does not appear in Windows Media Player when connected
Go intothe Settings menu of the Sansa and change USB Mode from MTP mode to MSC mode or vice versa
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
No power
I am having the exact same problem. I put songs on the MP3 player and it hasn't worked since. I'm not getting any help or support. If you find out what the problem is, please contact me. This is is so disappointing to buy a Xmas present that doesn't work!
[email protected]
Dec 27, 2007 | GPX MW3837 MP3 Player
Frozen on.
Problem resolved. I just let it sit until battery went down far enough for "Battery" alert to come on screen.
From there I put a charge on it and everything works fine now. Probably I should have kept it charged up.
Nov 28, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Player wont play certain albums when getting close to being full.
There is a maximum number of songs allowed (1000 for 4 GB) so you are probably over this magic number - they are still listed just don't play. I don't have solution for you - just a reason why.
Nov 22, 2007 | iRiver T60 MP3 Player
Corrupted files
all i can say is try to format the mp3
Aug 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
