Question about Ariston Technologies Ovens
Ariston TC720 electric double oven.just had power cut and now the timer is flashing and i cannot reset it to operate the main oven. Grill and top oven are still working. any ideas?
Posted by vjswing on
Anonymous
Hi
I have exactly the same problem, did you have any joy sorting??
Posted on Mar 31, 2010
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
I have a Zamussi ZUQ875 double oven. I have just replaced the bottom oven element after it went bang. Nothing tripped out but the digital display has gone out and cannot get main oven to work because
i suspect that you did cut power to the oven when you replaced the element. therefore the oven needs to be reset as new. there are quite a few pages of instructions on setting the timer so be prepared if you are going to to proceed with this "little" project.
I was able to locate your manual online here:http://kitchen.manualsonline.com/manuals/mfg/zanussi/zuq_875.html?idRes=625295
I suggest unplugging it for a few minutes...then plugging it back in. Hopefully if the electrical is good you will see the oven's timer flashing. then you can proceed with the instructions from page 7.
Otherwise, you may have a blown a short and should get a licensed electrician to look at it.
Another option would be to contact the manufacturer:[email protected]
Or, find the bloke that installed it and invite him over for dinner and maybe he'll notice it's not working and will fix it for free! ;-)
Good luck mate!
Feb 22, 2012 | Zanussi ZDF490 Electric Double Oven
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
Electric grill is intermittant or cuts out after 5/10 minutes
There are two overheat devices in the oven. One feeds the oven timer/programmer for the main oven and the other feeds the grill. If the cooling fan is running ok, then I would suspect it is the cutout feeding the grill elements that has perhaps with age is not working as it should do.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
847 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
