Question about LG Neon GT365 Cell Phone
How to fix an invalid sim card
I bought an at&t LG neon go phone. i already have an at&t go phone. i am trying to put my sim card into my new phone but it says invalid sim card. My other phone is still on but the sim card will not work on the new phone.
Posted by howardchisti on
  • Anonymous Mar 28, 2014
    Snapfon EZ two phone is telling me invalid sim card what do I need to do
Anonymous
    New Friend:
Try a different sim card if that doesent work then it might be the phone
Posted on Oct 21, 2010
2 Related Answers
Hilton Bristol
  • 567 Answers
SOURCE: i bought an at&t lg neon go phone. i already
Hi there i think your new phone lock, you should buy a New Universal Cell Phone Turbo Sim Card Unlock GSM Card from ebay, it only cost $1.00 and can be use to unlock any cell phone its interesting i think you should try it.
Posted on Jul 12, 2010
koronotoaja
  • 1487 Answers
SOURCE: i have a ATT go
You can't simple change your sim card to another phone, your lg phone must be unlocked first. To unlock lg neon gt365 you must have lg unlock code for your lg phone network carrier. This code can be purchased at third party sites for small price and you can do unlocking by your self since you also get details instruction how to unlock your phone.
Posted on Sep 26, 2011
I bought a unlock code for my lg gt365 neon and i put a tracfone sim card in it and it says emergency calls only how do i fix it so i can use a tracfone sim card.
First you need to unlock your phone before you put tracfone sim card on that phone. Make sure you have appropriate LG neon GT365 unlock code example : if your old sim card using t-mobile you must use t-mobile unlock code for your phone not tracfone. You can get lg unlock code from online seller with lower price and quick turnaround.
Aug 28, 2011 | LG Neon GT365 Cell Phone
How do i find the puk code on my lg neon phone
Hi there, it is printed on the voucher of the sim card when you have purcchased it, and it is related to sim and not with the phone..PUK means "Personal Unlocking Key" and it is asked if you enter wrong pin for three times. You are then given 10 attempts to enter the PUK. Your sim card will be blocked permanently if you still entered incorrect PUK code after the 10th attempt.
And if ever you lost the voucher you have only 2 ways to get rid of the PUK code:
1. Replace the sim card or 2. Call the phone company that released the sim card. They will give you the PUK code once you give them your account details and they have confirmed your identity.
Hope this can help you,GoodLuck=)
Aug 15, 2011 | LG Neon GT365 Cell Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
My lg neon gt365 is permanently locked because i entered the worng code three times, so now it says that the puk code is blocket & it only lets me dial emergency numbers. what can i do? or can you guys...
PUK stands for Personal Unblocking Key. This is a uniqueeight digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Feb 14, 2011 | LG Neon GT365 Cell Phone
I bought an at&t lg neon go phone. i already have an at&t go phone. I am trying to put my sim card into my new phone but it's saying invalid sim card. my other phone is still on but the sim card...
Jul 12, 2010 | LG Neon GT365 Cell Phone
It says puk
when your phone say puk then call to your sim costumer care and ask about puk. its related to sim, not to your phone
Tenzin
May 12, 2010 | LG Neon GT365 Cell Phone
I bought a new go phone and my old sim card wont work in it
Just go to provider, replace the old SIM CARD with new one. They will be give you the new SIM CARD with the same number ofcourse...
Jan 25, 2010 | LG Neon GT365 Cell Phone
My mother got an LG Neon GoPhone. She's been using her SIM card on it and it's been working just fine, but when she activated the SIM that came with the phone and tried to put it in the phone, it says...
It's normal since your phone still locked. You must unlock your phone first with lg neon unlock code for your phone network carrier. This code will reset your phone network to default factory setting so you can put any sim card on that phone. Lg unlock code can be purchased at third party sites on internet.
Dec 27, 2009 | LG Neon GT365 Cell Phone
I bought a new AT&T Go Phone and put my old at&t sim card in it and it worked for three days. Now I get a sim card not provisioned mm#2 message.
Maybe you need to unlock your phone network with lg neon gt365 unlock code for at&t network. This code can reset your phone network to default factory setting so you can easily change your sim card with other sim card even form other network provider. To get lg unlock code you can purchase at third party sites on internet.
Nov 25, 2009 | LG Neon GT365 Cell Phone
LG Neon GT365  Cell Phone Logo
2,982 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
William Alequin
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
