Question about Hotpoint WMA58 Front Load Washer
The machine won't spin or wash but it will pump the water out from the WMA58 could it be the timeing control or that area of
Posted by aum98 on
Gerry Harvey
    Genius:
  • Hotpoint Master
  • 1,482 Answers
You need a motor brush kit to fix.......9/10 works...
Posted on Feb 17, 2010
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
My washing machine doesn't want to fast spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 23, 2011 | Hotpoint WMA58 Front Load Washer
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Dec 13, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Model wma58 as soon as the machine finishes it wash cyle and is to empty water gushes from them soap dispenser area .Is there a blockage causing this fault.
Probably blocked filter, remove lower rear cover, locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Please rate my solution.
Thanks.
Mar 05, 2009 | Hotpoint WMA58 Front Load Washer
Hoypoint WMA58 won't empty
As you have probably found out, hotpoint washing machines do not have any customer accessible pump filters...
If you want to get on and fix this yourself you will need to get machine out and tip it up. have a look underneath. You will need tools etc.
1. Firstly check the power is off / disconnected.
**Next double check the power is off / disconnected.**
2. Check for obstructions inside the sump hose leading to the water pump. These machines have a filter/flap located in the sump hose which can get jammed up. See link http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=636775&brand=&model=WMA58&part=sump
3. My bet is that the pump itself is faulty. Check visually for blockages inside it - (do not dismantly)
For a replacement see the following for info on the pump. http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=640428&brand=&model=WMA58&part=pump
4. Finally I have heard of hotpoint wma's failing to pump water because the heater element is faulty -because water temp never reaches correct heat so programme halts.- but I cannot confirm this. To prove this put your machine on Final Spin - the first thing it does is empty the machine - no heating...
if it does then its probably the heater.
Regards
And don't forget to rate; thanks!
Feb 27, 2008 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 Washer won't do proper final spin
I ve come across this problem many a time... my job is recondtioning these models of machines for the last 3 years..
This problem has three solutions..
the first one is the control board,, very unlikey but has been known,
secondly the wiring loom unlikey but has happend.
Thridly the motor itself ....This is the most common remedy to this problem.
Dec 23, 2007 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
