Televison & Video Logo
Posted on Feb 17, 2010
10 year old 35'' Zenith TV will not respond to an RCA remote control. What code do I enter in order for it to communicate?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4130
Points
23
These codes are built and programmed into the remote and directly into the recievers. unless you have a universal remote then this rca remote will not work. they both communicate on different wave lengths and under different recievers.
1helpful
2answers
Lost remote for zenith H27F56S,so I bought rca universal remote, and have all the codes but still wont work to set up channels.I have followed the set up process to the "T" yet it still will not...
Sometimes the setup procedure might be not right. Check it with an other code. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given. Zenith TVs should synchronize with codes to RCA. Check the number of digit codes, that the TV asks. If it is a three digit one, and you are entering a four digit code, the TV won't synchronize.
1helpful
I have an old Zenith T.V. that works perfectly except that it can not be controlled by the brand new remote I bought. It appears that the T.V. does not respond to the remote. The remote has codes for...
If you have tried all the codes for the tv, and none of them work, the tv might be too old to respond to the newer remotes. Check that the batteries are inserted properly into the remote.
Some older tvs are just not compatible with todays systems.
I need the code for a rca remote (rcr311w) for a zenith TV
I am very happy to help you reprogram your RCA RCR311W for your Zenith TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up on this remotes device code list.
I hope that helps.
1helpful
HOW TO PROGRAM RCA RCU430 UNIVERSAL REMOTE CONTROL TO A ZENITH TV
Hello Lorielevi,
Follow the steps below.
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code at the bottom.
Release CODE SEARCH.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
here are the code for Zenith 001 056,061,068
hope this sort you out. If it does then please leave a thumbs up
Cheers Little Dish Fitter.
2helpful
3answers
Remote codes
http://www.oneforall.com
Hope this helps.
Len
4answers
I need codes for a rca d770
Programming For TV
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn’t, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
Emerson ..................1004, 1006, 1012, 1014, 1023
..................................1024, 1025, 1026, 1027, 1028
..................................1029, 1030, 1031, 1033, 1034
..................................1035, 1036, 1038, 1039, 1041
..................................1042, 1043, 1044, 1046, 1047
..................................1123, 1124, 1162, 1171, 1176
......................................................1177, 1179, 1191
Your user manual is available for download and option printing at the following link :
http://www.retrevo.com/s/RCA-D770-Universal-Remotes-review-manual/id/402ci568/t/1-2/
20helpful
3answers
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
1helpful
3answers
Code list
here are the codes for progamming your remote to zenith televisions...
000, 001, 004, 051, 083, 151, 152, 153, 154, 210, 217
hope that helps
2answers
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
