You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
The vibration is usually an unballance, check the freezer fan blade for any broken pieces. The water freeze will cause the Ice maker to not work..if the fill valve for the ice maker leaks, even a small bit it will freeze up on that "inlet ramp" if so, replace the fill valve. Else, I've found a unit not used, left alone for a week or more.. that tube still freezes up...gets too cold?
Unit is functioning on the back up freeze timer.
Cause:
Float Switch stuck in the up position.=Empty sump, remove float switch (Carefully and watch the small pin that keeps the float inside). Clean and reassemble.
Water Valve leaking by:=Only fix is to replace. Turn unit off. If water continues to run in and overflows the sump, it's leaking.
The other things that can cause this requires a qualified tech as it is a refrigeration problem.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
You may have a related problem. If the freezer compartmentisn't sealing off it will have excess moisture inside eventually making excess ice build up on the water inlet tube on the ice maker. Otherwise the water inlet valve is not closing completely and a little bit of water is building up and freezing.
