Question about Pentax Photography
How to make date etc appear on back of photos
How to make date etc appear on back of photo.I have set the current date on the back of the camera, but as I have lost/misplaced the user manual I cannot re,e,ber if it automatically appears on the back of the photos.
Posted by auntychook on
Anonymous
    New Friend:
  • 12 Answers
The date usually only appears on the front. However, most retail photo labs (i.e. walmart) can add custom backprinting to your photos. You can usually only add one line of text for entire order and custom pricing would probably make this a little bit expensive. On that note, the date you have your film developed/printed is usually printed on the back of each print for free, as this is default setting for the lab's printer.
Posted on Feb 18, 2010
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
Apr 19, 2012 | Konica Minolta DiMAGE G500 Digital Camera
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS ON MY CANON REBEL T2I
theres no date a time stamp on the photo itself with DSLRs but the meta data is kept on file in the photo so it has recorderd the time and date. depending on what photo printing software your using you can bring up the time and date back on the photo. I have canon photo printer and using the bundled software easy photo print, it allows me to print time and date of the photo. or if you use adobe lightroom you can get the time and date back on the photo. the time and date stamp is more of a compact camera rather than DSLR.
Dec 03, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
Date stamp will not appear on photo. i was told that there is on/off setting for this in the general setup menu called "date stamp" however,the model "vivicam 3765" has no such setting. how do i get the...
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jun 13, 2009 | Vivitar ViviCam 3765 Digital Camera
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Jan 06, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Date stamp on photos for Canon SD100 IS
I believe you are referring to the PowerShot SX100 IS, as there is no SD100 IS. And yes, it does have the date stamp option while the image size is set to the postcard mode.
Jan 05, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Date stamp on photo
Check the options carefully, and read the manual.If you don't have a manual, they are free for the download at Sony. Look for you camera under support/downloads.
Some cameras only allow date and time stamp to be in certain resolution settings. It will not show up in other photo size settings.
Jun 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Embedded date on photos
this camera has an internal clock battery, which must keep the date or any other related information while you changing the batteries, the problem is, since you camera is pretty old, the clock battery is probably long dead, it can be changed, but it will require disassembling and resoldering
Aug 19, 2007 | Kodak EasyShare CX4310 Digital Camera
Photography Logo
80 people viewed this question
Top Pentax Photography Experts
Richard C Cohen
Richard C Cohen
Are you a Pentax Photography Expert? Answer questions, earn points and help others
