Question about Altusen Aten CS62U-2 Port USB KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked but the switching function didn't work !
    New Friend:
  • 16 Answers
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Posted on Apr 23, 2010
Will this pc work with a generic monitor/keyboard mouse combo
yes it should work, and if the machine were not malfunctioning, would he have brought it to you
Mar 07, 2013 | Computers & Internet
I recently got a Vibe keyboard and mouse as a gift. Both are wireless and use one USB plug together. The model number is Kb-262. I can get the mouse to connect, but the keyboard will glitch and suddenly...
yer you are,switch the computer off, then plug in the keyboard & mouse...i'm thinking the GREEN ps2 port for the mouse & USB for the keyboard...
put batteries in them both,make sure their not dead batteries, then locate the little connect button on the bottom of them both, & the one on the receiver as well.
get a pin or something of the sort, so you can press these connect buttons.
switch the computer on, then once its booted up..press the button on the receiver @ the same time as the connect button on the keyboard,if not then the receiver first then the keyboard.
once connected, do the same with the mouse......receiver button then mouse connect button or both @ the same time...
you'll get it in the end,you'll need to do this ever time you change the batteries.
GOOD LOOK!
Sep 10, 2011 | Computers & Internet
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Unable to connect Logitech cordless keyboard
Of course you know to press the connection button on the receiver then on the keyboard. Since setPoint is recognizing the connection I wonder do the multimedia and function keys work? Do you have the the USB receiver for the KB/Mouse plugged into a hub or KVM switch? If so plug it directly into the back of the PC. See this KB http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9247
Jun 11, 2009 | Logitech Wave Cordless Desktop
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
I don't know how to cut and paste my story on to my you tube web page
highlight the parts you wish to copy by selecting with left mouse button. Now hold the CTRL key + C key (thats the kb shortcut for copy)
Next, go to your webpage and use CTRL+P (kb shortcut for paste)
Sometimes the mouse function for cut and paste may not work with all sites..
Try this first and let me know..
May 24, 2008 | Computers & Internet
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
1,206 people viewed this question
Top Altusen Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
