Question about Linksys WRT160N Wireless Router
Drops wireless devises at any time, now I can't
Drops wireless devises at any time. Had everything connect for 3 weeks and it just dropped everything - laptop, IPOD touch, Wii game consol. I tried uninstalling and reinstalling and it will not recognize anything.
Posted by takarsk on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Try hard-resetting the device.
Posted on Mar 24, 2010
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
My Belkin N750 DB intermittently drops my internet connection to both wireless and ethernet connected devices. I POR it and it works fine until the next time it quits. Is there a fix or is this just an...
Some people turn everything off at night and then when they turn things back on everything starts powering up. If you do this, it may be the problem because you have the modem and the router starting up at the same time. If the router finishes before the modem then it will drop.
Just make sure that you turn your wireless router on after the modem had booted up. This problem also happens when you have a power outage in the house and they both boot up at the same time.
When ever you are experiencing drops, just go unplug the wireless router then plug it back after about 30 seconds.
Jun 03, 2012 | Belkin N750 DB Wireless Dual Band N Router
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
We keep getting dropped for known reason .
Your internet modem needs to be reset to find the router first. The modem will find the first address when rebooting the entire system or if something gets unplugged..
I've had great success doing the following:
First of all turn off ALL computers, routers, modem ...everything... Then connect power to the main routing source... usually you've got your modem plugged into this.. Just start the router first with all ethernet cabling etc disconnected. Then secondly, connect power to the modem... As the modem connects, it will find the router ip address first... then you are set to turn on the wireless, and the other computers... and the router should designate proper ip addresses for all the peripherals and keep them connected without dropping someone off to allow the other address on... Hope this is clear.... So first the main router, then the modem followed by everything else... Let me know what happens ... and if you need more help...
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
D-link WDA-2320 wireless adapter keeps dropping signal
are you using XP if so you can restore your computer back to a date when it was working or you can try this
Use the Windows XP SFC command to have windows scan and repair files; to run this command, follow the below steps. Additional information about the SFC command can be found SFC command page.
  1. Click Start
  2. Click Run
  3. Type "sfc /scannow" and press enter.
Once the above steps have been completed, Windows will verify that all protected windows files are intact.
Feb 12, 2009 | D-Link WDA-2320 (ASKU54036) Wireless...
My laptop suddenly cannot connect to the router.
It comes down to a few things with routers and wireless connections:
1. If you have been dropping the signal over the past few weeks try doing a test on the wireless network connection via the diagnostic tool within the specific wireless connection.
2. You may have gotten a bad update to the wireless card. Try uninstalling it and then reinstalling it.
3. Try deleting the wireless connection for your router and then make 'a new' wireless connection.
Oct 15, 2008 | Belkin (F5D7230-4) Router (587009)
N1 Drops when Mac log onto network
OMG I have the exact same problem. I'll be using the router for a week on wifi just fine, then one time when my mac laptop comes out of sleep and tries to connect, the router drops its Wifi network (making it unjoinable for any device, not just my laptop) and I ultimately have to hard-restart it. SO frustrating, this is on v1 btw.
HELP
Feb 20, 2008 | Belkin (F5D8231-4) Wireless Router...
Dropping internet connection
check if this problem is with both wired and wireless computers, if not with the wired..only wireless has problems, check if you have any other wireless device operating in the same frequency of the router..if s, turn off other devices and check b.cos that me interfere your w/ls connection, if wired is having the same problem, connect modem straight to the pc and observe the connection, so that you can isolate problem..
Nov 04, 2007 | SMC Barricade 7004 Router
Linksys WRT160N Wireless Router  Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
