Question about Sony Cyber-Shot DSC-F707 Digital Camera
On my Sony DSC-F707 the hue is off so bad that blue things are green and the reds are flourescent-like. Can this be adjusted?
  • Anonymous Feb 17, 2010
    I forgot to note that it doesn't matter how white balance is set. On auto it is way worse. It's almost like no blue is coming through at all.
  • Anonymous Feb 18, 2010
    I have reset the camera, twice, and it makes no improvement. When I switch to nightshot or nightframe it makes an audible click sound at the lense and the display goes very grey-green. I believe that is normal, but I have just purchased the camera so I'm not so familiar yet. Perhaps there is a filter that clicks into place for nightshot. I am starting to believe that the camera has been tweeked for better night use and I was not told. Or it's just out of adjustment. I have heard that the first run of these cameras were heavy on green and red. Probably costs alot to have it adjusted, too. Don't know yet.
    Brigadier General:
  • 11,967 Answers
You might need to set the white balance to auto WB.
Posted on Feb 17, 2010
Testimonial: "That last statement to return the defective item hit the spot."
  • Ty Price Feb 17, 2010
    1. Have you tried pressing the reset button?
    2. Are you somehow set in "nightshot" or "nightframing"?
  • Ty Price Feb 18, 2010
    I wasn't aware that you just purchased the camera. I would return it...it sounds defective.
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Lcd screen on sony dsc f707 is green
After much money at repair shop for green viewfinder,
3 minutes ago I rapped my F-707 sharply on the
camera bottom, and green disappeared. Everything
else appears to be normal now.
Jan 05, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
No blue
go into the menu on the tv when its on they might have like a hue adjustment thing u could try to mess around with..
Oct 28, 2008 | Sony KP-57WS500 57" Rear Projection...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony F707 LCD/VF green tint
I tried the suggestion by sony and it worked! They said to hold the on-off buttom for 30 seconds.
Nov 16, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
57" Sony Wide Screen Projection TV with a green hue
You were given some pretty good advice but what you need now is a BK467 crt tester and the pin-out connections. Each tube, especially the green, will need to be tested for high/low emmisions and shorts. Don't take it on faith that having it rejuvenated will work for anything other than temporary either. You're probably lloking at replacing at least the green crt and it ain't cheep..
PS, don't kill the messenger either - - I don't like giving bad news and any shop you take it too will not relish in telling you what I just did.. I have 20 years in the repair industry and it's never pleasant telling a customer it's time for considering an new TV...
Nov 05, 2007 | Sony KP-57WV600 57" Rear Projection...
Undo White Balance Sony F707
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
178 people viewed this question
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
