Question about Whirlpool Duet GHW9150P Front Load Washer
Washer locked. door lock light blinking. start button light on. won't do anything.
Posted by everickert on
its222
    New Friend:
  • 59 Answers
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Posted on Feb 17, 2010
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
I have a Frigidaire front loading washer LTF 2140FS2 that will not start. I press the Start button door locks, press again the Wash Cycle light comes on. Then after a few seconds all the cycle lights...
Hi
Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Daniel
Sep 25, 2011 | Frigidaire Washing Machines
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Door won/t lock to start washer
by pushing all the buttons the door finally locked and the washer started, thanks anyway.
Sep 29, 2009 | GE Dishwashers
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,352 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
