Question about Life Fitness T3 Treadmill with Advanced Console
Error 1 message on older life fitness t3 treadmill
I have an older life fitness t3 treadmill and it starts and runs for about 5 seconds and then stops and gives me an error 1 message any idea what could cause this?
Posted by c1buehner on
  • Anonymous Mar 20, 2014
    Starts running then stops
  • Joseph Aderemi
    Joseph Aderemi Nov 15, 2018
    HOW LONG HAVE IT BEEN WITH YOU? MOST TIME ALL MACHINERY NEED SOME TIME OUT, MEANING THEY NEED TO BE SERVICED PROPERLY BEFORE THEY BECOME ALIVE AGAIN.
Anonymous
  • 83 Answers
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
  • 1 more comment
  • Sean Kennedy Mar 18, 2012
    What should the voltage be? 55.6Vdc???
  • Pfmcguigan May 13, 2012
    Mine has two green led lights on and the orange light down beside motor flickers for about five seconds then stops and e1 error flashes up and treadmill stops. Can you help
  • imahrguru
    imahrguru Jan 09, 2013
    We bought our T3 used tonight and put the two main piece back together, but no manual. Can you tell me what you mean by verify opto operation in Diagnostics Motor Test...means?
sdzeba
    New Friend:
I have treadmill t50 its says fet error and start up error.
txs
Posted on Feb 07, 2011
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Open Questions:
See all Life Fitness T3 Treadmill with Advanced Console Questions
Life Fitness T3 Treadmill with Advanced Console Logo
3,033 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
