Question about KitchenAid KESA907PSS Electric Kitchen Range
F2 E0 - KITCHENAID ELECTRIC RANGE
F2 E0 - HAVE THIS ERROR CODE ON DISPLAY AND CAN'T CLEAR IT.
Posted by dotcolli on
Dan Webster
  • KitchenAid Master
  • 8,220 Answers
F2-E0 Shorted Keypad Replace Keypad
Note if keypad is replaced and same code ,
replace control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 17, 2010
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Gives codes F-2 &F3 what is the problem [email protected]
    Hi, Error Code F2
    An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
    Error Code F3
    F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
    Hope that helps.
    Thanks for using fixya...
    Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
    Display reads EO -F2- stove top works, oven will not
    F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
    2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
    Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
    My kitchenaid keri203 is showing E0 in orange and F2 in blue on my oven display
    F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@
    Aug 30, 2010 | KitchenAid KERI203PBS Electric Kitchen...
    Controls won't work. Displays message: E0 -F2-
    Hi
    Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
    Kitchenaide range trouble codes
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@@@
    Mar 13, 2009 | KitchenAid KESA907PSS Electric Kitchen...
    I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
    That mean that the key pad is shorted,needs replaced
    E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
    Or
    E0-F2 Oven temp too high
    1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor
    Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
    F2e0 error on stove
    Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
    --> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
    Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
    Kenmore electric Range model 635040L0
    Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
    Kitchenaid Oven won't work E0 F2 on the control pad
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$
    Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
    KitchenAid KESA907PSS Electric Kitchen Range Logo
    764 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Marvin
    Marvin
    wp4eld1
    Level 1 Expert
    gbob59
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
