Question about Smith Corona Office Equipment & Supplies
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
Posted by savvyis on
Eric Sandbo
  • 159 Answers
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Posted on Feb 18, 2010
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
How do we use the correction on a smith corona sl 470
Provided that you have a fresh correctable ribbon and lift off and they are properly installed type a letter, press correction key the correction should take place.
DickyO
May 21, 2012 | Smith Corona Typewriter SL470 Refurbished...
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
How do you put the font wheel back in to match up with the keys in a Smith Corona typewriter?
When you put it in, make sure the charachters on the "printwheel"are facing AWAY from you. (towards the paper.) And make sure it is latched in place. Put the ribbon and correction tape back in properly. Turn the machine on. The printwheel should automatically reset itself. If it doesn't, it need professional help
Jan 05, 2011 | Smith Corona SMC10230 Typewriter
Silver sterling manual smith corona ribbon keeps falling off
you may have place the ribbon spools so they are unwinding instead of winding up the ribbon. The left spool turns counterclockwise and the right spool turns clockwise. Make sure the ribbon winds onto the spools when turned in those directions.
Nov 17, 2010 | Smith Corona Office Equipment & Supplies
Smith Corona PWP 4002 fails to type,. need to know if ribbon is correctly installed as well as circular disk. Thanks
Did you buy an OEM or COMPATIBLE ribbon? If you bought a compatible, please make sure you have bought the correct design for your typewriter. Some compatible ribbons come with a lug that prevents them from sitting correctly.
I note that you posted this problem over a month ago. If you haven't solved the problem by now, i would advise you to contact www.inkribbonpaper.co.uk. I have used them a number of times with great success for our smith corona, brother and royal typewriters
Nov 23, 2009 | Smith Corona Office Equipment & Supplies
143 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
