Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic 47in.hdtv when i push the on button it will blink 5x then go away then come back on ect... no picture please help thanks philip
  • Anonymous Feb 16, 2010
    it is 2004 model
Anonymous
    New Friend:
My tv pt-47wx42f turns on eor 8 secunds an than turns off
Posted on Mar 03, 2010
47IN LG FLAT LCD SOUND AND NO PICTURE
IF you are etting sound but no picture it means that your backlight are not coming on. You will need to replace your baklight inverter. You need to get the part number directly from the part itself.
You can get get parts for this tv at www.interliquidparts.com
Nov 18, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a panasonic pt-56dlx75. the lamps are okay i had them checked but my tv will not turn on, no blinking red lights just a green blinking light in the power button. I can also still hear a fan working...
I am not familiar with your TV but the blinking light is generally the error code! You will need to count the blinks, that will tell you what is wrong with your TV! Wish I could help you more!
Jan 07, 2011 | Panasonic PT-56DLX75 56" HDTV
47in dlp tv that turns on then shuts back off
The lamp may be bad or a fan has stopped running. Remove your lamp and see if it's shattered or dark and gray in the center. Also your lamp timer could have reached it's limit. check your manual to see how you can reset the timer only if the lamp looks clear.
Jan 29, 2010 | Panasonic PT-47X54 47" Rear Projection...
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Distorted picture
it may be the light engine. push in the menu and device/input button and it will give you a 2 blink code ect. 22 something like that
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
