Question about JVC KD-G421 CD Player
IPOD CONNECTION I BOUGHT A JVC KD-G421 STEREO AND WAS TOLD THAT THE SMALL BLACK JACK PLUG THAT COMES OUT THE BACK OF THE STEREO WAS THE IPOD CONNECTION ,BUT WHEN I FITTED THE STEREO IT DIDN,T WORK DOES THIS MEAN THAT I HAVE THE WRONG CABLE,AND DO I NEED TO GET THE JVC KS-PD100 Interface Adaptor For iPod
Posted by DUMBARSS on
  • ali_b_1 Sep 02, 2008
    I have the same problem too with my ipod touch, was told in halfords the aux thing might need switching on but ive read the online manual and it just mentions the adapter thats like 35 quid of ebay
Alphanso Tee
    New Friend:
  • 169 Answers
You need the jvc cable compatable for that unit
Posted on Jun 16, 2019
5 Related Answers
Anonymous
SOURCE: Using an external mp3 player on my JVC KD-LX111
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
Posted on Apr 18, 2008
Anonymous
  • 3422 Answers
SOURCE: Ipod touch
Do you mean that your PD100 adapter doesn't recognize your new ipod touch?
If yes then i would suggest you to only use the adapter which has been given to you with the ipod touch.Do not use anyother one.If you don't have one it is better to buy another new adapter.
Goodluck
Posted on May 10, 2008
Anonymous
SOURCE: I have a JVC KD-G421 cd/wma/ipod player and am
i have the exact same problem!!! need help. wont select the input channel, i have radio and cd??? wheres the mp3
thanks
Posted on Oct 11, 2009
josetejas
josetejas
  • 300 Answers
SOURCE: unable to set the clock on jvc kd g421
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Posted on Jan 22, 2010
Anonymous
  • 17 Answers
SOURCE: does the jvc kd-sx930 have rca jacks on it?
it should most do
Posted on Feb 24, 2010
How do I program EXT IN?
www.jvc.fr/...manual/kdg421ex_get0352-003a_fr...
May 15, 2015 | JVC KD-G421 CD Player
Jvc firmware
If you are using adapter, KS-PD100, it is possible that new iPods wont work with this older adapter, I would recommend to connect your iPhone via AUX on the front of the unit
Jul 30, 2014 | JVC KD-G421 CD Player
How do I connect my Ipod to a JVC KD-G230?
The cord you are using is an audio cable with a 3.5mm plug with two black bands on the plug. The JVC Source button has to be pressed until AUX shows in the display. The volume on the iPod AND the volume on the deck affect the sound - turn the iPod up to 70% volume for best results.
Mar 28, 2010 | JVC KD-G230 CD Player
Unable to set the clock on jvc kd g421 car stereo. Any suggestions?
Jan 14, 2010 | JVC KD-G421 CD Player
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
I have a jvc kd-g720 stereo in my car and when I plug my iPod into the usb port it says "do not disconnect" and even though i have about 2,000 songs on my iPod the stereo will only play the same 49 ones in...
if you are plugging your ipod into the usb port of the kd-g720 it won't play all your songs because this particular radio only plays mp3s through the usb port. ipods play both mp3s and mp4s. so those 49 songs you're hearing are the mp3s on your ipod. in order to play all the songs on your ipod you must buy the cord that plugs in the back of the radio that will connect to your ipod. sorry for the bad news man. i had the same thing happen to me.
Sep 01, 2009 | JVC KD-G720 CD Player
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
KD-G421 in Vectra Envoy 99
To stop the memory loss you need to swap the red and yellow wires around. (battery power and ignition power).
To stop the date loss, you need to cut the electrical ariel/remote blue wire.
Dec 27, 2007 | JVC KD-G421 CD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
