Question about Samsung SCX-4720F All-In-One Laser Printer
I have a Samsung SCX4720FN all in one printer and am getting the errormessage 'open heat error' - how can I fix this?
Posted by anthony582 on
Craig Gillette
    President:
  • 2,306 Answers
If you can test with a meter, you can find out if the fuser heater lamp is bad, the thermistor is bad, or there's no power to the fuser. www.precisionroller.com will have a new fuser for you if you can't repair the old one.
Posted on Feb 16, 2010
  • oasupport Apr 22, 2011
    already changed d new fuser ,main pba & power supply but d prob. is d same : fuser over heat smell
I refill the toner for samsung scx4720fn .Now its show toner empty replace the toner on the printer lcd. How i can slove this problem.
Dear raju
Pl. replace the toner chip with a fresh. As the toner chip known as CRUM stores the data about toner and printer irrespective of physical qnty. of toner. The chips are available in local market also you can search with on line stores like ebay,amazon etc.
Thanks.
Mar 16, 2015 | Samsung Office Equipment & Supplies
Samsung Printer SCX 4300 message "Open Heat Error"
on printer, in menu there is clear setting, find it and do ""clear setting" , "all setting", then will be fine
May 29, 2011 | Samsung SCX-4300 Monochrome Laser...
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
OPEN HEAT ERROR
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Mar 02, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Open Heat Error on samsung SCX-4521F
Nov 27, 2008 | Samsung SCX 4200 All-In-One Laser Printer
My Samsung CLX-2160N is telling me it has a "Low Heat Error, Cycle Power" ... but when I cycle the power it does not fix the issue. What can I do to fix this? John [email protected]
I do believe that the low heat error is talking about having low heat at the paper fuser (the part of the printer that makes the writing stick to the paper). This can either be caused by a bad fuser or by a bad controller board that is connected to the fuser. There is not much that you the user can do to fix this problem. I would take the printer to an authorized repair center in your area.
Nov 12, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Open heat error on gestetner printer/copy/fax machine
Aug 01, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Error Message
Good Luck!!!
neo
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4720F All-In-One Laser Printer Logo
289 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
