Question about Panasonic KX-FP155 Plain Paper Thermal transfer Fax
Fax Machine Panasonic KX FP155 has transmission problems
Fax Machine Panasonic KX FP155 has problems transmitting, phone lines working. Audio message says "transmission interruted" after half page tries to go thru. Tried cleaning rollers and related parts, no help. Any Ideas?
Posted by its222 on
pawan5871
    New Friend:
  • 54 Answers
Press menu#9000* 717 2 set
Posted on Mar 03, 2010
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Transmit Error
To eliminate a machine problem, make a copy of something; you are using the scanner to verify if the mechanics are OK.
To eliminate a phone line problem, take the fax to another house or office and try there it again.
Oct 30, 2009 | Panasonic KX-FPG391 Plain Paper Thermal...
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Carl
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
I wish to buy operating manual
go to panasonic,com and down load manual for your model number
Feb 02, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Answering machine
there is a 4 digit pin or may be more numbers either on the bottom of the machine or with thre manual that came with the machine usually when you retrieve from the out side u pucnch un the numbers and lets u get your messages. good luck
May 23, 2008 | Panasonic KX-FP155 Plain Paper Thermal...
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
Feb 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxing
check weather the phone cord is connected in teh line jack on teh fax not in the extension>and set resolution-standard>and auto answer mode-o>and error correction mode-off>or u have over seas mode-it should be on>u have either any one of this>and baud rate-9600> check with band width on the pc>and reboot it>and check rate me solved if its help full
Oct 31, 2007 | Panasonic KX-FP155 Plain Paper Thermal...
Panasonic KX-FP155 Plain Paper Thermal transfer Fax Logo
223 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
