Question about Avaya Corded Phone avaparp18d
I have an Avaya Partner 18D phone here at work, I had reset the phones accidentally. Now everything works fine, besides the page button. I am unable to press "intercom" then "page all" to say anything to other departments. The furthest I have gotten is being able to program the former 'pageall' button to one phone in the department, and im able to speak to everyone in that department that way, but what about the other departments?? Also, some calls, NOT ALL, when they come in, the phone rings once and it is picked up for some reason by i dont know who!
When you reprogrammed, did you do #505, group 7 to tell the phone system what ports the voicemail was? The voicemail is picking up because the ports are set to ring (which gets turned off, when you tell the system those are voicemail extensions by using #505)
If there were phones that were paged before, my guess is that they were in a calling group, then there were buttons set to page the calling group. (Intercom *72, 73, 74, etc) Intercom *70, pages overhead as well as the phones in group 1 (71)
Posted on Feb 16, 2010
How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
Mar 15, 2010 | Avaya Eurostyle 18D Corded Phone
Avaya 18D phone only speaker works not the handset. Order a replacement phone and the new phone does the same. We swapped locations snd the problem goes with the phone. Handset placed on a known working...
Avaya Partner 18D Button phone:
Two possible solutions,
First, could have a bad handset cord.
Second, I have come across a bad handset connection ports on the Euro style phones. The handset cord and the port just don't mesh well or the port itself is bad.
Feb 09, 2010 | Avaya Partner 18 Eurostyle 18D telephone
Ayaya Lucent Partner 18D Cordless call waiting.
The cordless will not work that way. If you hit flash, that will put calls on hold, etc....
The only thing you can do is have the flash button on the 18D itself.
Aug 28, 2009 | Avaya Lucent Partner 616 Phone
How do you reset clocks on Lucent Partner 18D phones?
The partner phones are now Avaya. The system time is going to be maintained by the operator's console or phones at extension 10 or 11 (the normal programming phones).
To set the system time, do the following:
Press Feature 00.
Press System Program (Left Intercom button) Twice.
Press #103
Enter the time in 24-hour notation (ex: for 4:23 p.m. use 1623)
A display should appear confirming the time.
Press Feature 00 to exit programming mode.
There is more information on setting clocks on various systems at
http://support.avaya.com/japple/css/japple?PAGE=OpenPage&temp.template.name=Daylight
The manuals can be somewhat difficult to find online. You may wish to contact your vendor to see if they can get you another copy of the manual.
Keep in mind that if you are using Merlin Mail you will need to set the time different on that system.
May 29, 2009 | Lucent PARTNER18 Corded Phone
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Which button is the 'feature button' on the Avaya Euro 18D phone?
It's the gray button labeled FEATURE just to the left of the #1 on the keypad.
Mar 09, 2009 | Avaya Partner 18 Eurostyle 18D telephone
Reset pasword lucent partner 18d
You will have to call in a pro. We can not put the master passwords on the open internet.
Dec 30, 2008 | Avaya Lucent Partner 616 Phone
Manual
A simple Google search found a manual covering the Avaya (Partner) 18d phone.
It can be found here:
http://www.getempire.com/media/guides/manuals/partner/456804_6.pdf
Good luck.
Mar 05, 2008 | Avaya Lucent Partner 616 Phone
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Avaya Corded Phone avaparp18d Logo
570 people viewed this question
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
