When using stereo or direct sound mode the sound on the two front speakers is fine. when enabling most of surrond modes the left channels (front and rear) emit noise and distortion and if too loung amp shuts down.
this happens with digtal input or analogue
extra surround and second main front speakers are not installed.
any help would be appreciated.
thanks
Iain
Ohhhhhh, so it has NEVER worked for YOU and it needed fixing when you got it. That changes everything. And you don't have the manual??
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of this unit anyway.
Make sure everything is connected correctly.
Look it over and play around with it. Speaker setup needs to be done before anything else. Did you get the microphone that comes with it? If not, go to page 23 and start there.
thanks for the reply. it used to work ok, and it is only just over a year old. not sure on the FM side as I don't think it was used. I have been given this amp, in hope I can get it fixed and use it myself. where I have plugged it up is a bit limited but I will move it and try to connect up to RF. what are the speaker setup modes? is this different to the DSP modes where it used between 2 to 5.1 speakers?
iain.
How does it behave when you use just FM or speaker setup modes? These would certify the speakers and amps are functioning correctly and then leave us with maybe identifying source issues. Is this a sudden onset problem or has it never or ever worked properly?
