2005 Volvo XC90 Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 05 volvo vnl 670, isx cummins 450/500. keeps losing power, check engine ECU comes on knowbody seems to know what it is. they just keep replacing sensors.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
7676
Points
12
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
  • 1 more comment
  • Anonymous Sep 25, 2012
    Are you ever find out what was the the problem on your truck? I have exact same problem on 2005 Volvo 670
  • Marshall Sheldon
    Marshall Sheldon Feb 19, 2017
    I RUN INTO THIS QUITE A BIT, WITH THIS COMPLAINT I START AT THE BATTERIES AND CHARGING SYSTEM, SOMETIMES ITS AS SIMPLE AS A LOOSE GROUND WIRE, COULD ALSO BE THE GROUND WIRES FROM STARTER TO FRAME AND STARTER TO ENGINE BLOCK, IF I DONT FIND ANYTHING THERE I CHECK THE IGNITION AND ECM POWER PLUG ON THE ECM, SOMETIMES ITS CORROSION IN THE ECM POWER PLUG, MAKE SURE YOU ALWAYS CHECK FUSES FOR A DEAD LEAG FIRST BET YOU WILL FIND ONE OF THE 2 ECM FUSES HAS NO POWER, I HAVE OVERLAYED THEM TO GET POWER AND THAT FIXES THAT. I HAVE NEVER FOUND WHAT THE ROOT CAUSE OF THE ISSUE ON THE FUSE SCENERIO.
  • Marshall Sheldon
    COULD ALSO BE A FAILED VECU.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
7676
Points
Hi everybody i bought a volvo 2005 cummnis isx 400 and ETN auto shift with a culuch . it runns ok but give me CHECK and says check engine ECU at nxt stop and the trasmission wont engage. it says code 1 but the cod chart i found starts from 111 can any body help me pls tnx mike
  • Francisco
    Francisco Dec 09, 2013
    i had the sameproblem with my volvo, and the problems was the batteries I have 3 bad of 4. Change batteries every 2 years
  • Marshall Sheldon
    ALMOST ALWAYS A BATTERIY BATTERY ISSUE OR TRANSMISION HARNESS.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7676
Points
Tengo un semi truck volvo indica en el tablero caution
  • gmurphy33 May 08, 2011
    it hard to give any kind of answer to your problem without more information....
    my first sugestion would be to check the wiring harness for bare wires shorting to the engine or frame...(volvo has changed the routing of the harness to resolve this issue) secondly if you you have the codes that would help narrow it down.(you should be able to call any dealer and ask them what the codes are and they will look them up. this will give you a better idea of where the problem lies.)
    good luck
Denis Aube
Level 2:
  • Expert 142 Answers
  • Posted on Mar 22, 2015
Denis Aube
Expert
Level 2:
Answers
142
Questions
0
Helped
115200
Points
551
What is the code / codes coming up on your ISX engine? Will probably be able to direct you for repairs if you tell me the faults. Most mechanics like to change sensors without researching cause for these faults, that is all too common!
Ryan Vercauteren
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Mar 20, 2015
Ryan Vercauteren
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
40710
Points
70
Follow this link and you will be able to check all diagnostic codes.
www.advantagetruckparts.com/pages/truck-repair-diagnostics.htmls
Anonymous
Level 1:
New Friend:
  • Posted on Sep 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7676
Points
On are 2005 Volvo 670 the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
  • 1 more comment
  • Anonymous Dec 14, 2012
    my truck does the same thing. Same year and everthing.
  • trucam
    trucam Feb 27, 2014
    We have an '06 and it was doing the same thing. We had the an injector replaced and a fuse that was causing the engine break not to work
  • Marshall Sheldon
    I RESPONDED TO ONE OF THESE COMPLAINTS ALREADY START WITH FUSES, CHECK GRAOUNDS ALTERNATOR AND BATTERIES. PROBLY DEAD LEG TO FUSES IN FUSE PANEL
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Dec 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
30417
Points
22
Try vehicule speed sensor,your ecm lock the rpm without vss reading. And this sensor give the info of the vehicule speed
What does the p225e00 code means,2014 d13 volvo 670 vnl?
P225E00 - nox sensor performance - signal stuck high bank 1 sensor 2
Where does the speed sensor cable lead to after leaving the transmission area in a Volvo VNL 670 2012. I want to know the exact location it connects to.
It connects to the ECU inside the car.....It is the signal letting the ECU know when to shift the transmission.....
4answers
Check engine ecu light keeps comming on 2006 volvo
Get OBD (on board diagnostic) from auto zone and plug it into car to read error codes.
I have a Volvo 670 2007 D12 and I keep getting fault codes ECU Maintenance MID 128 PID 27 FMI 5 and MID 128 PID 245 FMI 9. Does anyone know what they mean?
These code are specific to Volvo and you will probably need to contact a Volvo service department to have them explained.
2helpful
2answers
Engine Faults on a 2009 Volvo VNL670 w/ a Cummins ISX
i have a 2009 volvo 670 automatic transmission. i have a fault code for the transmission. RANGE LOW ACTUATOR
( VALR )
ELECTRICAL FAULT
INACTIVE.
does anyone what those codes mean?
I have 2005 volvo truck comuns isx eng .that dont picup gas
Fuel line. Check fuel filter and fuel pump. I fixed like this engine fitted on Iveco and Freightliner and other Prime movers.
My cooling fan is not working on vnl670
Check the fuses, then the fan relays, after that the coolant temp sensors.
The fans should come on when the AC is engaged so check to see if that part is still functioning.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Top Volvo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Volvo Expert? Answer questions, earn points and help others
