Question about Canon Office Equipment & Supplies
Getting problem with a canon ir 6000 error code e 350 -001
Posted by kevin seew on
ganu1234
    New Friend:
Ir 6000 problem e350
Posted on Mar 09, 2011
Ngoro
    Top Expert:
  • Canon Master
  • 2,647 Answers
2 Related Answers
Anonymous
SOURCE: getting a problem with a canon ir 6000 error code
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail [email protected] ty
Posted on Sep 16, 2010
Anonymous
  • 371 Answers
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Posted on Apr 15, 2009
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
Ir 6000 error code 0061-01
It just Need Cleaning (or change) of Primary Carona Wire
Nov 04, 2013 | Canon imageRUNNER 6000 Copier
IR 6000 - Error conde E10,E12 and E14 after 5 to 10 min of starting
Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link:
http://goo.gl/yhuA4J
thanks
Jan 12, 2013 | Canon Service Manual For Ir 6000
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
When i put my canon IR 2318 on, the code E000010-0000 appears; what can I do to move it?
this is error code for main motor failure, you can try to reconnect main motor, look for breakege of gears, reconnect dc controller, or the main motor must be replaced or dc controller, or ...
As you can see that there is a lot of things that can be fault, so call service!!!
Aug 28, 2011 | Canon imageRUNNER 6000 Copier
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Getting a problem with a canon ir 6000 error code E 350-001
Feb 16, 2010 | Canon Office Equipment & Supplies
805 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
