Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Starts its program then stops,no water going into machine
Anonymous
    New Friend:
I had the same problem, apparently it was the anti flood valve, turn the water supply off, then disconnect the hose from the inlet valve, drain any water that's in the hose, reconnect it and the machine should work, mine did
Posted on May 24, 2010
Anonymous
    New Friend:
I had a problem for a long time(years) with dishwasher several mechanics etc could not find problem. turned out the anti hammer valve on the tap was broken so no water or not enough
Posted on Feb 16, 2010
Testimonial: " unfortunatly when i checked all valves are fine i can get water from main feed through check valve through hose to the machine but still nothing"
Half way into the spin cycle machine will stop. Does not go to next level of high spin. Does complete and go to stop position, but clothes have done a part spin and are quite wet, previous to this spin...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The program does not go to the next higher cycle as the processor does not activate. Choose another program and if there is no action or ouput to the motor then the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Hoover 750 top loader goes through cycle drains but will not spin if you manually put it in spin it will not stop fills up and rinses drains but will not go again into spin until manually do it then again...
Two issues are possible , After the first start of the wash , check if the machine starts only when the water level is reached- to confirm the working of the water level sensor.
Secondly if the program cycles seems out of hand then it is possible there are errors in the program controller unit.
Hi, our washing machine starts to pump out water and then stops. The counter still keeps going but without the machine actually doing anything. The water doesnt drain out sometimes and the no drain light...
Possible failure of the main program controller unit as it fails to contact at times and resets .
Since you mentioned that it is erratic the program is not executed to contact to the job of the cycle and so the drain pump/valve is stopped mid way.
1helpful
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Dishwasher stopping mid program
sometimes machines stop to heat the water. does your machine ever start again?
if it does not start on its own, it could be a time issue, or a heater element issue. if it calls for heat and it never heats, it will never run.
if it ever drains, then the issue is not the pump. its a logic board.
good luck
mark
2answers
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Top Tricity Bendix Dishwashers Experts
Marvin
Marvin
Steve Pack
Steve Pack
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
