Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
My tv screen constantly distorts the picture.
It looks like a moving frozen picture. It's hard to explain but hopefully you get the gist. The sound is fine when it does this but the picture is just completely gone. The picture breaks up in moving lines and disconfigurements. Does anyone know what is wrong with my tv or have experienced it as well?
  • 11,361 Answers
More likely to be the problem in the LCD controller (TCON) board due to heat problem, try running the TV with the back open with small fan blowing at the top section of the TV. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Becareful wehn removing the back, you may have switch assembly attached to the back cover.
Posted on Feb 16, 2010
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 60pw938 TV where the power light comes on and then you hear constant clicking and thats it. Any suggestions on how to troubleshoot?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Philips 60PP9202 60" Rear Projection...
Zenith R45W46F has sound but no picture
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 27, 2010 | Zenith R45W46 45" Rear Projection...
Picture is wavy and double vision
*Screen Looks 3-D
*Colors wont align
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
*Screen Looks 3-D
*Colors wont align
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Componants in back don't seem to work, HD cable,
*Screen Looks 3-D
*Colors wont align
Oct 22, 2009 | Philips 55PW9363 55" Rear Projection...
I have Diagonal lines moving across the screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 15, 2009 | Toshiba 51H83 51" Rear Projection...
Fuzzy/ distorted tv pic
*Screen Looks 3-D
*Colors wont align
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Picture all distorted cold warms up ok
*Screen Looks 3-D
*Colors wont align
Dec 06, 2008 | Toshiba 57H82 57" Rear Projection...
Viewing problems
*Screen Looks 3-D
*Colors wont align
Nov 01, 2008 | Samsung HCL5515W 55" Rear Projection...
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
393 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
