Question about Whirlpool GU2300XTS 24 in Builtin Dishwasher
Have Whirlpool dishwasher #GU2300xtsqo. White
Have Whirlpool dishwasher #GU2300XTSQO. White soap residue caking inside of dishwasher, glasses cloudy and etched, stainless silverware discolored. What's wrong?
Posted by janice_damia on
  • Anonymous Mar 28, 2014
    SOAP REMAIND
D. Floyd Kolb
  • Whirlpool Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 04, 2011
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishes, moeetly the glasses and silverware are cloudy. I don't think its etching. I think it is soap. I can't get it off. I have tried different soaps and rinsed agents and nothing helps. It is...
You can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
If soaking or cleaning with vinegar works then try adding some to each cycle to see if the clarity of the glasses improves.
Dec 09, 2010 | Maytag MDB6650A Built-in Dishwasher
I bought this dishwasher 2 weeks ago. The dishes are not always clean, the glasses on the top rack have a residue that gets dried on (white/gritty) and the glasses have a white film on them. I have...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Nov 06, 2010 | Viking VDB450 Dishwasher
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
After a complete cycle now have a milky residue
The milky residue on the glasses is not a residue at all: it is irreversible damage to the glass and is caused by a myriad of microscopic cracks in the glass surface combined with surface etching. Vinegar only works if there's a limescale deposit caused by using too little salt (no salt at all, or the salt dispenser set too low, or just not adding supplementary salt in a hard water area when using dishwasher powders with an in-built salt function)
It can happen to most glassware, but will happen very quickly to lead crystal which is why every single dishwasher I've ever sold or rented out says not to put them in the dishwasher. So called "glass protection" dishwasher powders are a marketing gimmick; all they do is to try and eliminate chlorides from the mix and boost the salt content, but they won't actually stop the damage completely.
Similarly, most advise against putting silverware in the dishwasher. By silverware I specifically mean anything made of silver, plated with silver or electroplated nickel silver (EPNS). Stainless steel is fine though. You might like to read this short article on the subject.
Mar 11, 2010 | Dishwashers
Cloudy glasses My dishes are not being cleaned. There is a white residue on my glasses and in the dishwasher itself.
You may have hard water. Are you using a rinse aid, you always need to use one. Buy some Tang drink crystals and empty a package into the soap dispenser and run the dishwasher through empty. If you can't buy Tang use about 4-6 cups of white vinegar thrown in the bottom of the machine and run the cycle. Sometimes the white residue on the glasses is there permanently and can't be removed it is called "etching" right in the glass.
Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
Cloudy glasses and silverware, they look worse coming out of the dishwasher than they did going in...almost looks like milk coating....I think it's due to hard water in my town...I need solutions
use product called lemme fresh and jet-dry use the walmart power soap only and the only thing i recommend to remove the cloudyness is citric acid at any pharmacy you have to ask for it use rubber glove wash by hand if it come off you in great shap if not its call etching and they are destroyed never use liquid soap for dishwasher harder to break down and do not choose the heating cyc it bake the soap on
Aug 20, 2009 | Whirlpool 24 in. Portable Dishwasher...
Whirlpool GU2300XTS 24 in Builtin Dishwasher Logo
638 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
