Question about Panasonic SDR-H40 HDD Camcorder
Dew detected - Panasonic SDR-H40 HDD Camcorder
Posted by salemanalex on
electronic & computer repair& servicre
  • Panasonic Master
  • 12,061 Answers
Try putting in a nice warm airy place for a day or so, it may clear the "Dew Sensor". Else it may have gone faulty. It thinks there is "Dew"moisture inside the unit near the record/playback heads.
Posted on Feb 16, 2010
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Dew Detected message
i have dew detected all the time that shuts down my camera
Dec 11, 2008 | Quasar VM-L459 Camcorder
Dew warnig de camara Panasonic Quasar
LA HUMEDAD CON EL CALOR ALTERA Y HACE QUE EL SENSOR DE HUMEDAD DE LA CAMARA SE ACTIVE. YO PROBE CON UNA SECADORA DE PELO DE MI MUJER Y ME FUNCIONO. LA CAMARA AHORA ESTA BUENA. HABRE EL MECANISMO DEL TAPE (CASETERA) Y SOPLA CON EL SECADOR DE PELO DURANTE UN RATO DENTRO DEL MECANISMO DE LA CAMARA TAMBIEN ALRREDEDOR DEL LUGAR DE LA BATERIA Y ALRREDEDOR DEL BOTOM ROJO REC-VHS-OFF, DEJALA HABIERTA UN RATO Y PRUEBA DESPUES PONIENDOLA A FUNCIONAR. DEBERA FUNCIONARTE CORRECTAMENTE Y SIN EL WARNING-DEW DETECTED
Jul 03, 2008 | Quasar VM-L450 Camcorder
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected error signal
Good Luck,
Luwangula
Nov 11, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic SDR-H40  HDD Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
