Question about Samsung DLP HL-P5663W 56" TV
Samsung HLS5686WX/XAA big screen has white dots, and they're multiplying daily....what part do I look for to fix this problem? I want to order the right part to fix it.
Posted by hockeyschwan on
Anonymous
    New Friend:
  • 14 Answers
Call Samsung! They do recall even if it's out of warranty.
They set a tech to come and fix it for free.
Posted on Mar 10, 2010
How do I fix the white spots on the screen of my samsung model HL-S4286W. The white dots keep multiplying. Is there a repair manual for this that you know of?
It is not a user repairable fault. It can be repaired. Contact the authorized service center for Samsung.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Samsung Televison & Video
WHITE DOTS ON SCREEN NEED DIAGRAM LOCATION AND REPLACEMENT HLT 56765X/XAA
White dots that increase in number as time goes by indicates that the DLP chip needs to be replaced. Samsung use to cover this problem under their "white dot" warranty. You can call 1-800-samsung to see if they will repair it. If not, they can give you the closest service center. I would not attempt this repair unless you are a trained tech.
Apr 05, 2011 | Samsung Televison & Video
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
White dots, multiplying daily.
This more or less means you have a bad hdmi plug, unlug it from your cable box and watch what it does if your tv automatically goes to the waiting screen and the white dots re apear its The hdmi plug, so the hdmi plug needs to be replaced...they arent cheap maybe 40-75.oo depending on how nice of pic you want
Mar 25, 2009 | Samsung DLP HL-P5663W 56" TV
WHITE DOTS IN MY SAMSUNG TV HDTV
the white dots our dead pixles im afraid the only way of fixing this is buying a new display, if you contact samsung and let them no they should be able to give you the price of a new display.
Thanks
Mar 10, 2009 | Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
752 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
