Question about Toshiba 36A40 36" TV
My 36" Toshiba 36" Cinema Series Tv has a white line running across the entire screen from left to right. Everything else Works just fine, sound, channel changing, etc...just the picture is black with this white line. What is causing this ?
Posted by greenrider7 on
Paul Bruno
  • 63 Answers
You need to have the vertical IC resoderd I think it is ic301
Posted on Feb 15, 2010
Thanks for your help. as soon as i turn on the tv there are white lines across the screen that shouldnt be there. and the entire screen slowly fades to white at the same time as sections of the tv freeze...
Tv still have audio sound after it is turn itself all white on the tv LCD screen panel?Yes.Than this problems it is the tv main tv Tuner signal board it is dying and the causes.That the board,where the tv imcomming broadcasting signal cable wire plug into it.U have some skills,like can do some basic mechanicals works like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main tv Tuner signal board for the replacement.
Aug 15, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
The picture with my television has gone out. The sound is fine but there's only a white line across the middle of the television. How can I fix the picture?
The Toshiba sets are well known for this problem, the tv has a vertical deflection issue caused by the vertical ic and a few small capacitors going bad, I recommend a tv technician for the repairs.
Jan 15, 2011 | Toshiba 36A40 36" TV
White lines running across screen from right to left
when there is a line from right to left it means a verticle amplifier is faulty, remedy
change a verticle amplifier IC
dont forget to check some capacitors (electrolitic for change of values)
this will solve your problem.
Apr 07, 2009 | JVC AV-36D303 36" TV
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
No Picture on my Toshiba television
Try hooking the tv up to the back with the right cords. Turn off 1st and replug the tv and turn back on.
Nov 26, 2007 | Toshiba 36A43 36" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba 36A40 36" TV Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
