Question about Kenmore HE2 Plus Front Load Washer
Aug 28, 2017 | Washing Machines
Apr 13, 2015 | Samsung Washing Machines
Hey Del Richard, thank you for your post!
It sounds like a possible issue within the control panel or drain pump. I would suggest seeking assistance from a professional to properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
Sep 28, 2014 | Dryers
Mar 03, 2014 | ZEEPAD Audio Players & Recorders
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Aug 17, 2010 | Kenmore Washing Machines
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Aug 19, 2009 | Washing Machines
Jun 30, 2008 | LG WM-1832C Front Load Washer
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
739 people viewed this question
