Question about Kirby G4 Bagged Upright Vacuum
Smells like burning rubber when I turn on my G6 Kirby vacuum.
Smells like burning rubber when I turn it on. I have a G6. I let my daughter borrow it to vacuum her apartment. She has a long hair cat and she hadn't vacuumed in a while. I had to pull hair out of the kirby from everywhere. and completely break it down. Now no matter what I do when I turn it on it still has that strange burning rubber smell after running for a few minutes. I've changed the bag and the belt. I also made sure everything was running properly as I could tell and all areas were clean. To include the beater brush.
Posted by rbounds08 on
seakish
    Master:
  • 492 Answers
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Posted on Oct 15, 2013
5 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Kirby g6 won't turn on
Alot of the time it is a bad cord, there are other reason like a safety switch not engaged, bad switch, or a problem with the motor.
Posted on Feb 17, 2008
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: owners manual for kirby g6
There is no manual available in file format, but you can get it on VHS, DVD and book format by clicking this link...
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Posted on Jun 22, 2008
Uplate
  • 112 Answers
SOURCE: dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
Posted on May 23, 2009
b0sslady2001
Marci Marple
  • 357 Answers
SOURCE: kirby G6 vacuum smells ok smoke when vacuuming and
Try my troubleshooting guide...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps,
Marci
Posted on Jun 28, 2009
Doug Connell
  • 715 Answers
SOURCE: Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Posted on Oct 17, 2009
Kirby upright smells like a foot. Changed the bags. We had to move it to the garage for storage beacuse it made the closet smell like bad shoes. Gets strong when used
Check the brush for accumulated hair, and other debris. If the brush is belt driven check the condition of the belt, over time the rubber deteriorates and melts when heated up during use creating a burning rubber odor.
Feb 24, 2011 | Kirby G6 Bagged Upright Vacuum
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Owners manual for kirby g6
The Kirby G6 Vacuum Manual is available for free on this site: http://ubermanuals.com/product/kirby-g6-8499 .
May 13, 2008 | Kirby G6 Bagged Upright Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
G6 Kirby Convert to Shampooer
Here's my online guide for using the Kirby shampooer....
http://reviews.ebay.com/KIRBY-CARPET-SHA...
HOPE IT HELPS!!
Marci
Dec 02, 2007 | Kirby G6 Bagged Upright Vacuum
Voltage
no!   It will be ruined if you try that.
Oct 16, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
939 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
