Nintendo DS Lite Console Logo
Question about Nintendo DS Lite Console
The light stays red when charging. will not take
The light stays red when charging. will not take a charge
Posted by hazelavenue on
Anonymous
  • 644 Answers
You will need to try another battery in the ds, if it charges then you will need to purchase a new one.
Also check the ds charger itself in another ds to ensure that it is working.
Posted on Feb 17, 2010
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Charge light won't stay on and therefore won't charge
It could not be making good contact with the charger.Check the contacts on the unit and the charger-sometimes the connectors get bent or something is stopping the circuit to complete. Wiggle the device while it is on charge and try to make the light stay on.
The red light above the chatging plug stays red when I am charging the computer. is it supposed to be this way?
Try removing the battery, hold the start button for 10 seconds, then reinsert the battery.
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
2helpful
My camera casio exz75 doesnt want to hold a charge
I had the same problem some time ago. I called Casio Live Support number and they sent me a new battery free of charge that works.
2helpful
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
3answers
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Top Nintendo Video Game Consoles & Games Experts
Aron
David Shaub
Marvin
Marvin
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
