Question about Maytag Neptune MAH5500B Front Load Washer
MHW2000 neptune washing machine: There is a burning smell when washing laundry
Posted by jjkkhh88 on
blueextc3221
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####@@@@@
Posted on Oct 01, 2010
I smell a burning smell from the washing machine--I have the Maytag Neptune which was purchased in 2002. What does this indicate? Can it be repaired and at approximately what cost?
Now 2002 is a pretty long time,and a burning small sound dangerous. You would need to service your washing machine. Checking for the health of the power cable and the parts on the panel board. If the manufacturers have a sevice center near you, consider taking your machine there. You may pay a fee for that but it will assure you that your Maytag Neptune is renewed!
Take Care.
Aug 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi, We just moved into
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Jan 01, 2011 | Washing Machines
My washing machine smells where is the filter does it have a filter all other machines do
Run a tub filled with a couple of quarts of white vinegar thru the cycles. It generally reduces smell of mildew and bacterial odor. Clorox works too. Run rags or other "throw-away" laundry during these cleaning methods.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Burning smell from washer
YOUR DRIVE BELT MAYBE WORN AND NEED REPLACEMENT.
Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine + burning smell
The load of rugs may have been too much for the device and there may have been considerable belt slippage causing the burnt rubber smell. Try another regular load and cross your fingers. And stay away from those outrageous loads!
Sep 06, 2017 | Admiral AAV7000A
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
May 16, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
222 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
