Question about RCA Video Cameras
Need Manual for RCA VHS Camcorder Model No. CC 285
Posted by d_eno on
Anonymous
    New Friend:
  • 44 Answers
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
Posted on Feb 15, 2010
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
May 15, 2011 | RCA CC-439 Camcorder
Is there a way to hook the Camcorder straight to the TV. The vhs adapter I have doen't work.
Here's a link to the manual for your camcorder. Take a look at page 11. There are composite (dont confuse with component) audio and video outputs. If your TV has the same type of inputs, then a direct connection between the TV and camcorder is possible. Otherwise, you will need a composite video converter to change the format to a specific channel, usually 3 or 4.
On the VHS adapter, try changing the battery (also in the manual as well) to restore operation.
Sep 27, 2010 | RCA CC6151 Camcorder
Battery on camcorder
its for the time and date clock
Jan 10, 2009 | RCA CC-432 Camcorder
Need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Nov 18, 2008 | RCA CC6254 VHS-C Analog Camcorder
Can't access all the menus...
Some RCA camcorders feature both Automatic and Manual recording modes. Some features on these camcorders are only available in Manual mode. Check to make sure the POWER switch is set to M, and not A, then try again. If you are unsure of the recording model features of your camcorder, refer to the owner's manual or the product catalog on the website. Look on the bottom of your camcorder to locate the model number.
Sep 06, 2005 | RCA CC-432 Camcorder
Do I need to set the date?
trying to find manual for this model
Video Cameras Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
