How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
SAFE MODE:
1.
Place you
finger on the on/off sensor leave it their until you console turns off then
take you finger off the sensor.
2.
Place your finger back on the on/off sensor
leave it their until you hear 2 consecutive beeps then take your finger off.
3.
Once the safe mode screen comes on select the
option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all
data except the OS. I recommend backing
up your console onto a USB flash drive if possible.
Good Luck!
How many times does it beep? Does it beep continuously or beep a few times (up to 9) then stop, then beep again, then stop and so on and so forth?
How many beeps?
