Question about HP LaserJet 3015 All-In-One Printer
Tried to load HP Laserjet 3015 s0ftware with printer plugged in. That failed. Now getting "finds new hardware" when I try to load the software even though nothing is plugged in. software is not asking me to attach the printer.
Posted by myersde on
mukhtar21 shaikh
    President:
  • HP Master
  • 2,022 Answers
The thing is printer is automatically detected by the system and there was no proper driver was installed and it is in device manger installed as other device with yellow mark. Just uninstall it. And click on scan for hardware changes. To go to device manager right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Have a nice day and do not forget to rate please...!
Posted on Feb 15, 2010
I have an HP LaserJet 3015. I got a new computer
- uninstall everything again
- browse your disc
- open "Setup" folder
- copy "Scrubber.exe" and "scrubber.ini" to your desktop
- run "Scrubber.exe"
- restart PC
- reinstall software
- enjoy
- p.s. this will not work under windows 7
1helpful
2answers
Hp 3015 auto feed
You'll have to replace the feedroller kit. Partnumber CB414-67918. Gerrit Jan
2answers
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
3answers
HP3015 All in One - new toner put in but printing very pale
Try going into the Maintnence Center, should be in Options or Maintanence and running it.
Problem with my Printer - HP laserjet 3015
I need a bit more information. Does it print at all or just does'nt copy?
If it does'nt print at all the problem is generally the toner cartridge. Have you tried changing the cartridge?
I tried to install my hp laserjet 3015 several times but I failed
  • It may take a little time for the CD to begin reading. Hit retry.
  • The CD may be damaged
  • The program may not load automatically
  • Go to the Start menu and then click on "Run". When the Run window appears, click on browse. Choose the D drive (or the one that reads your CD). Look for a file that ends in setup, execute, or install (these words my be abbreviated)
  • Double click on the file and it should be displayed next to "open" in the "Run" window.
  • Click okay and the program should begin to install.
3answers
HP laserjet 3015
Good Evening MOKSHAKUMAR:
Hope that you are wellJ
Try this first:
Click start, then in search box type printer. A menu should come up that will permit you to troubleshoot your printer.
You did not indicate whether you were getting an error message or not.
Have you tried to uninstall and reinstall the printer and if yes, do you have the same problem each time?
Did you attempt to install new drivers for your HP 3015? This may well be the problem.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
2answers
HP 3015 No fax detected
did you ever get a response to this? i am having the same problem.
Hp 3015 not installing
Problems seem to occur when printer cable is plugged in before software is installed.
Delete driver and software installed, disconnect printer from PC.
Download and install correct driver to suit, connect usb when software prompts to do so
Make sure the driver you are installing is correct for you system
LINK to DRIVER DOWNLOAD
HP LaserJet 3015 All-In-One Printer Logo
Ekse
k24674
