I am trying to activate my bluetooth on my Samsung sgh-u700 but get an error message that reads Bluetooth activation failed or it hangs on the screen that says activating Bluetooth. Please assist
Thanks. I tried both and loaded everything new but now it hangs on the screen that says "Activating Bluetooth"Thanks. I tried both and loaded everything new but now it hangs on the screen that says "Activating Bluetooth"
You can't post conmments that contain an email address.
try try without SIM: *2767*2878# Custom E2p reset if this doesn't work, then try: *2767*3855# Full Reset but be careful, because the last code will delete everything in your phone.
try
Hy gcahig, follow the instruction (note :if my solution was helpful please rate the answer) :STEP 1. Locate the Bluetooth Settings Menu To pair the handset with a Bluetooth Device follow the steps below:
From the standby screen, press the right soft key for Menu
Select Settings (9)
Select Bluetooth (6)
STEP 2. Activate Bluetooth and Search for Device
Select My Devices (2)
Search for the Bluetooth device by pressing the left soft key for Select
Press the left soft key for Yes to Activate Bluetooth and start the search
STEP 3. Pair with Selected Device
Highlight the desired Bluetooth Device, using the navigation keys, then press the left soft key for Select
Enter the Passkey "0000" then press the left soft key for Select
The handset will display a brief message stating connecting followed by connected
After being successfully connected you will return to the "My Devices" screen.
For Windows Vista
If you've misplaced the PC-connecting cable that should have come with the phone in the box, try connecting to the software via Bluetooth. Of course, you'll have to make sure Bluetooth is on for both the phone and the PC for that.
Cheers. =]
Please pair the device with the phone? if not then read the manual of the bluetooth and pair them first.Also try turning the cell off & removing the battery and then turn oin again to see if the issue is solved.
your bluetooth inside the phone does not make proper elctrial contact on the board ta it to the service provider to re install the bluetooth device. advice by dogy.
Yes I did without any success
