Question about Dual XDVD270 Car DVD Player
I have an XDVD271 and the picture flickering or skipping. The audio is fine. What is going on?
Posted by seals_robert on
12345pj
  • 5 Answers
Try to check/toggle the int - ext A/V switch on the left hand side of the unit, that might solve it if it is only on one screen, if it is on both it is most likely the DVD player itself, try with a clean good DVD to check if it could be a dirty or scratched DVD.
Posted on Jul 15, 2010
How do I fix my LCD TV's ability to display picture?
it may be from inventor board that make light for screen.
Apr 18, 2016 | Sceptre X322bv-hd 32" 720p Hd Lcd...
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
What would cause the head lights and instrument panel to flicker on a 2009 dodge journey
The headlight switch might be the reason the headlights are flickering. Pls try to turn off headlights and see if the instruments still show strange behavior.
If the problem persists, try pulling fuses (one at a time) to see if you can find the circuit which is causing the problem. There might be intermittent shorts / no connection in a circuit other than headlights.
Dec 04, 2013 | 2002 Dodge Durango
Screen blinks and then goes out. tap on side and causes flickers
sure sounds like loose solder joints, look for them in the deflection circuit, just find the hard plastic encapsulated body with the thick red wire sticking out of it thats where usually the loose solder joints develop.
Sep 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
Clarion radio sound flickers
make sure your wirings are rated to handle the current needed by your radio. You might have a large voltage drop when it is at high volume level because it will draw lots of current. You might need to change the size of your wires to your Clarion. Check the voltage near the radio when it starts to flicker if it goes below the source voltage of 12V. hope this helps
Aug 17, 2009 | Clarion M475 CD Player
Will play games but the audio cuts in and out
the audio skipping like that mean that the wires are shorting or frayed... you will have to replace your audio cords. Just as a note if this doesnt fix it theres a chance its inside the ps3 or just your audio reciever. Oh, before you go buying the audio cord try messing with the audio setting in the menu first, it might just be your audio sampling is set too low
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
Hitachi skips over commercials & flickers
If by saying the "aspect ratio changes" you mean the picture shrinks from top and bottom, I would suspect an intermittent short inside one of your picture tubes. The commercial skip function is not causing a problem here. It is the rapid change from dark to light that I believe is putting an extra strain on a weak or defective picture tube.
Jan 18, 2007 | Hitachi 43FDX01B TV
Dual XDVD270 Car DVD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
