Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
How do you unlock the tray for the panasonic sc-bt200 .when i press the button to insert a disc it says the word lock and it won"t open
Posted by dmj7 on
Frank Black
  • 69 Answers
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
Posted on Feb 15, 2010
Agustin E. Rodriguez
Greetings, I bought a Used Panasonic Home Theater SA-BTT268, I try to open the disk tray but it tells me that it is blocked I have looked for information on the internet on how to solve this case and I can not find anything, the little information I find is that it must be to put a 4-digit password but does not mention when or what it would be
Posted on Mar 07, 2021
Grekomon
    New Friend:
  • 3 Answers
If you bought an open box floor model at a retail store it was probably locked by a Panasonic rep. The previously suggested fix does not help from what I tried. Still looking for a fix. Try Panasonic support 1-800-211-7262, Mon-Fri 9:00 AM - 9:00 PM EST
Sat-Sun 10:00 AM - 7:00 PM EST.
Posted on Feb 22, 2010
  • Grekomon Feb 22, 2010
    I tried calling 800# all they could add to the previous suggestion was to leave unit unplugged for a few minutes and try again. I know the unplug technique works to remove the demo mode from Panasonic TVs but it didn't work for our SC-BT200. Might have to get it serviced to fix. Hope someone else has another fix.
Panasonic SA-PT170 disc tray will not open
You may as well replace the player, as the parts to fix it are not available for this type of device, just no demand .
Jan 31, 2012 | Panasonic SC-HT70 System
Beim Firmware Update stopt das System bei UPD5/5 - keine weitere Reaktion ???
the firmware update for sc-bt200 & sa-bt200 takes approx 10 mins. the box will display UPD5/5 - this process takes about 10-15 minutes, the box will switch off automatically. Leave for 30 seconds, and power on manually with your remote control - the screen will display - "firwmware update completed.".
Feb 05, 2011 | Panasonic SC-BT200 Home Theater Systems....
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
Disc tray on Insignia BRDVD player will not open. Any help would be appreciated. Press the open/close button and display says either open or close. The tray does not eject though.
the disc is probably stuck out of the tray and stopping it from opening. unplug, and you should be able to pry open the front case and pull the tray out.
Apr 13, 2009 | Panasonic SC-HT730 System
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
