Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Screws for fin inside drum have fallen out. I
Screws for fin inside drum have fallen out. I need to replace the screws. What is the best way to access the exterir of the drum in a Maytag Neptune MD5500?
Posted by rdscharris on
geapptech
    Habit-Forming:
  • 157 Answers
Remove the top
Posted on Feb 15, 2010
One of my dryer fins fell off how to get it back on
Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
Change is stuck in neptune dryer someplace. would it be in fins inside drum or in the drum? is there an easy fix or does dryer have to come apart?
You have to pop the top so that you can remove the screws holding the fins to the drum. to do so you must first remove the door. Opposite the door hinges is 2 more screws that must be removed. You can next remove the goalpost shaped front panel by popping the clips that hold it on. That reveals the hooks that hold down the top. Once these are removed the top will come up. Then you can remove the screws that hold the fins on and get them pesky coins out.
I have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 • Dryers
2answers
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 • Dryers
1helpful
How to I get to the drum? The fins in the drom have come unscrewed and fallen off. I need to get to the outside of the drum and screw them back on.
Access to the outside of the drum requires the removal of the front then the top panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the screw holes appear at the top of the drum and screw the baffles back into position.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Note: This guide is for Maytag Sloped-Front Dryers.
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
One of the tumbler fins inside the dryer has come loose and fallen out. How do I repair it
gotta open it. usually screws are inside dryer. 3 screw hold it. make sure u unplug unit b4 putting hand inside
1helpful
Remove and replace fins in drum
ok
1. take off the door hinge screws,
2 take off the two opposite the hinge
3. lift the door up and out
4. graqb the slim side walls on either side of the door way
turn them in and pull the whole panal tword you
5. once you have the door cowel off, you should see two top dogs screwed down with 2 5/16
romove those and the dogs
6. with the top dogs off you should be able to lift the top, like the hood of your car
7. once the top is up , you will have access to the tumbler top and the screws for the fins should be right on top
2helpful
HE3 dryer drum metallic noise while spinning.
The baffels are pretty easy to take out.
You will need a quarter inch nut driver.
First, you remove the top cover of the unit off by removing the 3 screws in the back. then each baffle will have 2 quarter inch screws and you can access them easily once the top cover is off.
Best of luck :)
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
2helpful
2answers
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
Top Maytag Washing Machines Experts
Jessie Goss
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
