Question about GE Profile WPRE6100G Top Load Washer
I have a ge top load washer that the tub is off balance.
Posted by tylevall on
steve
  • GE Master
  • 3,361 Answers
Open the control panel to get the mini manual. It will show how to remove the front panel and check the tub supports.
Posted on Feb 15, 2010
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: washer tub goes off balance every time and washer walks!
there may be a possibility here of the centre hub being worn or the liner tub bearing being worn due to the age of the machine.. here is a list and diagrams of the parts you may need and can get from here:-
http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=mat13mn&searchTerm=img_CW17-6&RefineSearch=0&imgMfg=Maytag
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
Posted on Dec 27, 2008
Anonymous
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
Anonymous
  • 130 Answers
SOURCE: Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
Posted on May 07, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
Testimonial: "Thank you. I think this sounds like exactly the problem I'm having."
Anonymous
SOURCE: WCVH6800J1WW GE Washer error codes
need same solution, please post
Posted on Jul 30, 2010
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My washer is very very loud during its spin cycle
There are a number of things that can do this. For a top-load machine, an out-of balance load can get noisy. Many GE washers have bungee-cord type straps at the top of the tub to dampen out-of-balance gyrations. If these break, you get a lot of rattling. Other washers (some older Kenmore models for example) have a spring-and-bar arrangement under the tub. If this freezes up due to rust, or something breaks, your washer will bounce a bit. Older Maytag washers may dance around if the baseplate is worn out. In all washers, bad tub bearings can make a racket; you will often have leakage as well.
Sep 09, 2014 | Washing Machines
Tub is out of balance; how can I fix this?
Ge has stabilizer rubber straps at top of outer tub remove front of washer remove 2 1/4 screws to remove top 5/16 screws hold 4 corners of top rim and 1/4 in scews under top frame replace all broken stabilizers then your problem should be fixed if still loud you may have bad trans
Jan 30, 2013 | GE WHRE5550K Top Load Washer
Washer tub has water but it will not drain
If you are refering to the sloshing sound when tub is moved back and forth it is supposed to be there. That is the balance ring. It is a liquid filled ring at the top of the tub that acts as a counter weight to keep tub balanced.
Jan 19, 2013 | GE WBXR2090B Top Load Washer
My GE washer acts as though it is off balance but redistributing weight does not help. The surface is level and checked with a level. Any other ideas?
counterweight brick under the tub if it has broken the straps holding it in place it will make loud unbalanced tub sounds quick and easy fix
Oct 06, 2012 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Washing Machines
THE TUB IS WOBBLING AROUND INSIDE THE MACHINE.
either the top tubs "balance-ring" is leaking the balance solution and needs replacing or the tub springs are broken or disconnected from the tub
Jan 01, 2011 | GE WJRR4170E Top Load Washer
Tub bangs loudly
there may be 3 to 4 load springs on the underside of the machine that attatches to the tub. if one of these breaks which often do on my machine. They will cause the machine to become unbalanced and bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
You can hear water still in the washer - not inside the tub where you put the clothes but inside the washer machine.
I believe you are referring to a GE top loading washer. GE uses a liquid filled balance ring around the top of the washer to help compensate for off balance load. The sound is perfectly normal.
Aug 28, 2008 | GE Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
439 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
