Question about RCA F32650 32" TV
RCA F32650 has low volume high pitched clicking or whistle as soon as it is plugged in. does not turn on.
    Genius:
  • 1,274 Answers
Replace the flyback
Posted on Feb 14, 2010
6ya staff
SOURCE:
Have a 27 in Rca t.v and it will not turn on. I also tried unplugging it, but still the t.v will not come back on how do i change the fuse
FORGET the fuse for the moment. If you unplug the set and plug it in do you hear a high pitched whinning sound?
This model is prone to the High voltage transformer failing and usually the Horz output transistor at the same time.
You hear a buzz if you unplug it and plug it back in?
SD TECH
Jun 24, 2010 | RCA F32650 32" TV
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
My rca tube tv has a high pitch whine when i plug it in no picture also
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Dec 20, 2009 | RCA F32650 32" TV
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Help me...
1)pull chassis-solder any/all bad connects. 2)Replace shorted horiz o/p xistor #237470 and IHVT #257805 or Asti 2078
Sep 02, 2007 | RCA F32650 32" TV
RCA F32650 32" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
