Question about Whirlpool 24 in. ADG7952 Built-in Dishwasher
Whirlpool dishwasher stuck on prewash cycle
Hi
I have a Whirlpool built in dishwasher, model ADG 957. It's currently giving us trouble - it won't let a cycle run and keeps returning to the prewash. Running a prewash first doesn't make any difference. The cycle will start and stop after about 10 mins and the prewash option will be lit up, and the start button will be flashing. Holding down the start button clears the flashing but doesn't fix the problem. Any tips or recommendations would be greatly appreciated, thanks!
Posted by jeanobrien on
exploreris
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
The eprom memory is brocken,the main board must be changed.
Posted on Feb 14, 2010
My whirlpool ADG 7540 dishwasher is not heating the water but is running through the programme
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
2answers
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 • Dishwashers
6helpful
Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
I accidentally put my ADG 4540 on prewash. it
You can continue. It will repeat the cycle and go further till end. But if detergent is required add.
Whirlpool ADG 957 Dishwasher not draining water?
There is a remote possibility that the drain line is clogged. Most units should have an aerator on the top of the sink area HOWEVER some are hooked up directly into the garbage disposal and it's at that point where the line can be clogged. Remove the clamp and make sure the line is clear or the hole in the disposal is clear.
Nov 09, 2017 • Dishwashers
1helpful
Whirlpool dishwasher ADG 957. The manual says " Open the door and turn on the water tap". Where is the water tap and what does it look like?
They mean to turn on your water faucet at the kitchen sink and let the water get hot before starting the dishwasher cycle this insures you start the wash with hot water.
2helpful
Dishwasher ADG7540
every time i choose a cycle it goes back rince and keeps bleeping .its a whirlpool adg 7540
3helpful
2answers
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 • Dishwashers
Whirlpool 24 in. ADG7952 Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Dan Webster
Dan Webster
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
