Question about Dell Inspiron 1000 Notebook
Replaceing fried hard drive on Dell Inspiron 1000, will the original retore disk work?
Posted by ciro_grassi on
Alun Cox
    President:
  • 2,679 Answers
Yes it should contain all the necessary info.
Posted on Feb 14, 2010
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
Dell Latitude wil a DST short test fail. error
you are correct, time to replace the hard disk drive.
Jan 28, 2010 | Dell Inspiron 6000 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
My insprion 1525 does not have the repair computer option in the advance boot options...how can I reboot the hard drive to factory settings?
If you have the retore disk, this will be your best option. Not only will it restore your system but also put the recovery partition back on your hard drive.
Good Luck
C2Solutions
Jan 23, 2010 | Dell Inspiron 531s Desktop Computer
Possible water or hard drive damage to Dell Inspiron 1000 Laptop
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
Deel inspiron 6000 error 1000-0146
Error code 1000-0146 is a hard disk drive failure, you'll need to replace the hard drive. If under warranty contact Dell for a replacememt. If not, you can buy replacements at newegg or other tech sites
Jan 26, 2009 | Dell Inspiron 6000 Notebook
Can I swap out a laptop Hard drive
the laptop has to support older harddrives. u;re fujitsu is IDE (ATA100)! So the other laptop has to support IDE also !
Jan 08, 2009 | Dell Computers & Internet
My Laptop Dell Inspiron
Check the disc for scratches, this could be a bad disc. However, I'm leaning towards another issue besides the hard drive being bad. Tell me what initially happened to make you buy a new hard drive. Hard drives aren't effected by the heat produced by the machine, so tell me what made you think it was heat that caused the hard drive failure.
Jul 08, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
