I have the side by side fridge w/freezer drawer on the bottom. The freezer stopped freezing and two days later the fridge stopped chilling. Is there something simple other than power to the fridge that I might be missing before I call for service?
What you have is probably a bad defrost heater element is my first inclination. I would look for frost buildup on the backside of the bottom drawer. That is a sure sign of defrost failure. And most defrost failures turn out to be broken heaters. The defrost heaters mount on the evaporator coils and simply heat the area for a few seconds to melt frost. If left alone that frost will trun into snow and then into air flow blocking slab of ice and fail fresh food cooling. I have a 3 door repair manual you may want to look through just to see what you are up against. To do this repair the ice maker and all the rails drawers bins and food must come out so you can get to the rear where the evap coil and defrost heater is located.
LG FRENCH DOOR REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
