Question about Nikon D70s Digital Camera
How can i change the size of image on the lcd screen
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the Zoom-in button (the one with the magnifiying glass) to zoom in. Press the Zoom-out button (the one with what looks like a part of a checkerboard) to zoom out.
Zooming in lets you look at a portion of an image, zooming out reverses it.
Zooming out also lets you look at thumbnails and navigate around them to select the picture you want. Then you can zoom in to fill the screen with that picture.
If you're looking at a picture full-screen, you can also press up/down on the multiselector to change your view of the picture.
Posted on Feb 14, 2010
6ya staff
SOURCE:
Change the image size on my TV screen? I want it to fill the screen
It will be in the menu under something like display or video settings. From there it will be a sub menu like aspect ratio. Your remote may have an aspect ration button on it as well. Some even list it as wide display or image
Feb 15, 2015 | Westinghouse Electric W1603 15.6 in. LCD...
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Whats the difference between a LCD and plasma
Answer: Outward appearances are definitely deceiving when it comes to LCD and Plasma televisions. Although both types of televisions are flat and thin, they employ different technology in an attempt to deliver similar results. Plasma TV Overview Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element). Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images. LCD TV Overview LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation). Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer. Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself. Plasma vs LCD The ADVANTAGES of Plasma over LCD are: 1. Larger screen size availability. 2. Better contrast ratio and ability to render deeper blacks. 3. Better color accuracy and saturation. 4. Better motion tracking (little or no motion lag in fast moving images). The DISADVANTAGES of Plasma vs LCD include: 1. Plasma TVs are more susceptible to burn-in of static images. 2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images. 3. Does not perform as well at higher altitudes. 4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements. LCD television ADVANTAGES over Plasma include: 1. No burn-in of static images. 2. Cooler running temperature. 3. No high altitude use issues. 4. Increased image brightness over Plasma. 5. Lighter weight (when comparing same screen sizes) than Plasma counterparts. 6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans. DISADVANTAGES of LCD vs Plasma televisions include: 1. Lower contrast ratio, not as good rendering deep blacks. 2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets. 3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public. 4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you. 5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions. For a more detailed look at the LCD and Plasma comparison, check out: Should I Buy an LCD or Plasma Television?
Jan 18, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
I am using a Sharp LCD projector XG-E1000UB. I do not have a manual...how do i project a smaller image..the image from the DVD player is huge..i want to project it on a screen in my backyard...
Although you can change the image size +- 10% from the projector ring, if you need to reduce the size significantly you will need to the reduce the throw of the image by moving he projector closer to the sreen.
Aug 15, 2009 | Electronics - Others
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung LN 53A550 Image size
you need to go into personal settings through the control panel on your computer and change screen settings for output 2. You may have to try different resolutions to fill the screen
Jan 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Connecting Toshiba notebook to Samsung LCD TV - small image only
because you have added a new monitor, you have to go into your graphics settings and set the screen resoloution to a setting your comfortable with
hope this helps
regards
Nov 20, 2008 | Computers & Internet
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Nikon D70s Digital Camera Logo
111 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
