Question about Maytag Neptune FAV6800AW Top Load Washer
Fav6800aw leaks water from clutch - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
I believe you may have a Tub Seal Leak you will need to remove the Outer Tub to start of the repair process for a Tub Seal replacement. I would start by removing the clutch I feel the water will coming down the Spinner Assembly support and or the agitator shaft driving the transmission.
See this post Clutch Fix for removing the clutch and inspecting and re-lube of the One-Way Roller clutches bearing. You will find links to the Service Manual at that post.
Read this post1 and this post2 for removing the Outer Tub Bearings and seals and special tool to remove Spinner Assembly. No doubt this is a big job but other DIY’ers have done if you can tolerate the down time.
I feel repair cost will trigger a washer replacement if a DIY fix is not an option for you.
I’m an owner not a repair person but have some hands on with the FAV6800A and have helped owners/repair folks out with FAV9800A LCD version of this machine…..Rich
Posted on Feb 14, 2010
6ya staff
SOURCE:
My maytag neptune tl stops after wash cycle it will start for a few secounds then stops and will continue this start stop action till i hit the stop button
The washer is trying to go into spin but failing. The two sprag clutches are probably sticking, This usually indicates a water leak.
The seal should be replaced. The bearing and sprag clutches should also be checked and will probably need to be relubricate or replaced.
Apr 15, 2016 | Maytag Neptune FAV6800AW Top Load Washer
I think that I have the dc error signal clutch problem, but my situation also had water leaking from the bottom of the machine. Could the 2 be related, and if the clutch is fixed then the leak problem as...
Yes the Tub Seal has failed and contimanted the Clutch Pulley.
One-Way bearings in the Clutch Pulley have failed to lock up in Spin Cycle causing tumbler movement to throw the wash load of ballance. This issues causes big time DC and UC unbalance errors.
Is it cost effective to repair? Yes if you do the work........Google this "" FAV6800A/FAV9800A Outer Tub bearing replacement "" Read thru the post and see if you can DIY the fix. If you want help I will assist on that forum.
Also see the link on this forum below.
I have a neptune top loading washer. Call PSEG service man out (had contract on washing machine).
Jul 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Washer leaking water on the floor....had a code of nf? I have been reading the message boards and they say could be water pressure sensor tube or switch...but where do I fink these in...
If you have water leaking out of the wash tub that sounds to me like it is the issue. How much water is in the wash basket when your Control Board signals the NF (No Fill) error code?
It's time to remove thr front cover and see where the water leak source is. If it's over the Clutch Pulley then you could have a Tub Seal issue. See if you can identify the leak source. Follow all saftey warnings in the Service Manual or call in a repair service........Big Dollars
See this post Clutch Fix I describe in the front of this fix action for dC/uC error codes how to remove the front cover of the machine.
let me know your DIY skills if you want to try a fix. I have many post on troubleshooting the Pressure Switch in the FAV6800A/FAV9800A machines in this forum both under FAV6800AWDIY and dh1200s logins.......D*ick
The Service Manual for reference. Sears Parts Direct for reference.
Aug 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
When it gets to the spin cycle it wont spin correctly the letters "dc" appear in the display window and it leaks water on the floor- sometimes if i turn the machine off then hit the spin button it will...
You may have a Tub Seal leak and I feel you definitely have Clutch Malfunction see this post Clutch Fix for the DIY. If you decide to go forward with a DIY fix I will try to help……Rich
Jun 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water leaks from bottom of washer at spin cycle
If it's a FAV6800AW or FAV9800AW you may have a leak in the dran line at the drain pump connection. You would have to remove the front panel to inspect. Do yo want to DIY or call in a repair company? Also can you confirm the machine model number. A ot of request for help in this forum are not FAV6800AW specific. If it'an FAV6800AW or FAV9800AW I will try to help.
Nov 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Does not drain the water
we had the same problem. First the repairman ordered and installed a new clutch. If the clutch is out, the spin cycle cannot do its job. But after the first load, it leaked. So for another $300 part he came today to replace a bearing and seal. Now the bearings under the tub need to be repaired at $500 for the part. We said no, no more money and now are going to have it picked up for $20!! You can start with the clutch and see if you can avoid the bearing issue we had. Sorry!!
Apr 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Tl washer
Mike, Sorry to hear that, is there any water around the clutch pulley?  With the front panel removed and you put the washer in a Spin Only cycle with no clothes in the wash basket.  View the Clutch pulley turning CCW and see if is turning true with no wobble? Mine spun off twice before I got it seated properly, and it was in wobble mode until I got it seated properly.   With the water leak issue maybe you can view with the front panel off and a partial fill the leak source. You can always do a quick tub pump out in service mode. As you know unplug the 120VAC to the machine before you poke around in there.  Do you still have the original clutch?  Did you remove the plastic cover and inspect the roller bearings, clutch spring and coupler? Good luck and let’s see what you find. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AWW top loader washer
Double posting, are you still having the issue, did reseating the clutch clear the issue?
Maytag Neptune FAV6800AW Top Load Washer Logo
311 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
