Question about Toshiba 57HX81 57" Rear Projection Television
Toshiba 57hdx82....Covergance failure.... This set has had a failure the reds and blues are very separated and now there is a "Ghost image" Almost 3D! Any ideas
Posted by bighank65 on
JOHN BABA
    Genius:
  • 1,274 Answers
Convergance board need to be replace
Posted on Feb 14, 2010
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Akai rear projection tv...picture is not deformed....however there are images (Ghost image) in separated colors...like 3d
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2010 | Akai PT5598HD 55" Rear Projection...
In convergence mode, I can't move red line up and down, blue line works fine. And my Toshiba projection TV shows double layer vertically.
once you have exceeded user intervention, condsider that the convergence boards are on the way out and will need replacing and retuning correctly Not a DIY as it requires special tools circuit diagram and knowledge of HT power and radiation protection.
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Goes from normal to weird colour saturation blues and reds seperated and ghost double images
It sounds as if the video card driver is on the blink. Try going to Toshiba.com and look for video driver upgrades for your system and download. Let me know if that works.
Thx
Aug 01, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Ghost red image
If you are connecting via HDMI, try either getting the firmware upgrade from the Philips website or switching to Component (Red, Green and Blue) cables.
Feb 17, 2008 | Philips 55PP9401 55" Rear Projection...
Tv has a ghost image in red
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 50H72 50" Rear Projection...
PLEASE HELP (Three Ghost Images)
You will need to have or change the convergence correction driver IC's. There are two of them in this TV set. Not a fix for a novice I'm afraid. If you have no solid state repair experience, play it safe and call out a pro to assist you in this repair.
Jul 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Toshiba 57HX81 57" Rear Projection Television Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
