Question about Sony BRAVIA KDL-40V3000 Television
Sony Kdl 3000 100MHz LCD goes to sleep briefly
My Sony LCD tv is 2.5 years old and now it just seems to go blank and reset itself over a 5-10 second period at random Have tried disconnection all feeds except aerial and still does it . Have recorded on HD recorder via same aerial as and at same time as TV and when TV goes blank the recording shows no blank
Is it another trip for the warranty man ?
Posted by jim_lewis656 on
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: Can't remove AV Input display
Try setting hdmi control to off in tv menu
Posted on Apr 06, 2008
Anonymous
  • 320 Answers
SOURCE: Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Posted on Nov 26, 2008
Anonymous
SOURCE: Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Posted on Feb 20, 2009
Anonymous
  • 92 Answers
SOURCE: sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
Posted on May 19, 2009
mahesh patel
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
My brand new sony bravia is cutting off by itself after 5/10 seconds.... Help!
1 Please check if the "Sleep Timer" is activated, or confirm the "Duration" setting of "On Timer" 2 If it does not work it is suggested reset all settings to factory settings.
Jan 13, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
I have coloured vertical lines covering my Sony Bravia LCD tv screen. The TV is only 2 years old. I have sound but a very distorted picture. The cable company has checked and says it's a tv problem. I will...
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Jan 02, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony tv, no pic or sound, lcd blinks
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Dec 31, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Usually resetting a device like that is done via it's On Screen Display (OSD). Maybe you need to contact Sony Tech support.
You can do this by clicking the below link:
[Sony Tech. Support]
Let me know if they have a solution to your problem.
Greetings,
DarkNeogen
Aug 20, 2007 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
